Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 02-25-2009, 01:57 PM   #406
Default Update
I know people have asked already but whats the update (release date) on 1/8 scale motors and ESC?
Sorry if this is repetitive
Jake
Bubonic-X is online now   Reply With Quote
Old 02-26-2009, 01:32 AM   #407
tc3team's Avatar
Originally Posted by NUCRPTRACER View Post
Yeah that's about where I am at....zero motor timing and then work the boost and dial in timing with track size,layout and conditions...
Sure sounds like you are good to go there...
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-26-2009, 01:37 AM   #408
tc3team's Avatar
Jake
No date as such, the latest I know of is that there was a minor setback with one of the moulding machines being broken
Not something that can not be replaced, just something that "has" to be replaced to get them through the production line, before they are then packaged up... and then sent out to distributors and retailers....
So the combination of processes makes it impossible to put a date stamp on it all.
I'd keep checking the Tekin Forum's RX8 sub forum for info about that.
Old 02-27-2009, 12:19 AM   #409
bender's Avatar
Bump for this question:
Originally Posted by bender View Post
I couldn't find this info elsewhere so I'll ask here - what would be a good starting ratio for a tekin 10.5 motor in a touring car, rubber tyres on a med grip track which is fairly large and has too good length straights?
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 02-27-2009, 12:27 AM   #410
LOSI123's Avatar
Trader Rating: 63 (100%+)
Bump for this ? too lol
Originally Posted by LOSI123 View Post
Cant find a thread for the tekin 17.5, so
What FDR Or Rollout are people running with this motor in a Touring Car with Li-po 7.4v, Sorex rubber(63mm) out door track Large/medium ashphelt. warm climate. Boost at max and motor at 0, car weight 1425grams
I hope this is enough info
Even just an approximate range?????
LOSI123 is offline   Reply With Quote
Old 02-27-2009, 02:17 AM   #411
tc3team's Avatar
I would turn a few laps with the same ratio a 19t uses for the same track, then bring the car in and monitor the temperature very closely as a starting point, and go from there. You may find you need an extra tooth or two.
Difficult to say for sure without knowing the track and the size of it, but also remember that any boost or motor timing changes will also affect your gearing.
More of either and you are usually looking at an extra 2 teeth or so on the pinion gear.
Just a very rough guide though, so as above, experimentation and monitoring the temperatures is the only way, unless someone else who races at your track knows better.
Old 02-27-2009, 08:43 AM   #412
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Most of the time I see an FDR of 4.5-5.0 depending on track size.
Motor temps are the biggest determining factor.
Something about winning attracts losers with opinions......
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, B-fast, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-27-2009, 08:53 AM   #413
hardrider's Avatar
Trader Rating: 39 (100%+)
I've seen the 10.5s run FDR between 5.3 to 5.7 with pretty decent temp readings. Use 5.5 as a starting point and adjust from there.
Hope this helps.
hardrider is offline   Reply With Quote
Old 03-02-2009, 10:30 AM   #414
LOSI123's Avatar
Can Some one from Tekin Prety Please with cherrys on top please let me know whats happening with my Email re:Motor Mount plate
I have sent 2. hopefully you at least have one, I was told you's had some email/ Website iussues.
Cheers
Old 03-02-2009, 10:50 AM   #415
Team Tekin
Randy_Pike's Avatar
Shoot it to me here: Rpike@teamtekin.com
What's it about?
Old 03-02-2009, 02:34 PM   #416
LOSI123's Avatar
What's it about?
Email sent
Old 03-17-2009, 05:13 AM   #417
LOSI123's Avatar
Thanks for the motor replacment part
Just also Want to let you guys know that i have now finaly played with timing and gearing on my 17.5 and its now Very fast
Old 04-19-2009, 03:37 PM   #418
Tekin: When will the TT2122 T35 Pro be available to purchase?
Sabin is offline   Reply With Quote
Old 04-20-2009, 07:53 AM   #419
Team Tekin
Tekin Prez's Avatar
Some 35Tpro handwound crawler motors and systems are shipping to distributors this week. The teardown motors that we handwind have become difficult to source lately. We are setting up a direct source, but supplies may be limited for awhile until this happens.
Tekin Prez
jcampbell@teamtekin.com
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline   Reply With Quote
Old 04-23-2009, 02:22 PM   #420
Default Yet another setup advice please-
Hi all,
Sorry for yet another post asking for initial setup help, but have looked in Tekin RS / Asso B44 tuning threads untill my eyes almost popped out of the sockets. Still confudes though and never really found anything for my type of car/track/ect.
Here goes.
Finally decided on trying offroad again. Has been away for a few years (active running large scale here in Denmark & TC5R with Sphere TC Spec/3.0 turn LRP) Fantastic car.
Now for my B44 which should arrive within a few days.
I'm almost decided on the Tekin RS Pro / 6.5 turn combo as this seems like a good setup from what I can read in several threads.
The local trask here is outdoor, carpet, quite high grip, 80 x 45 feet, long straight, fairlt smooth and includes the usual washboard, dual/tripple jump and so on, so need grunt to pass these also.
I will be using 6000 Mah Hyperion saddle packs.
So what kind of gearing ?. As I understand it the B44 comes stock witg a 84T 48P spur gear. Is there some kind of rule fo thump regarding the final drive or what.
Also for you Tekin goys. Regarding programming (will buy the Hotwire of cause) what settings should I start with? I'm udes to drive brushless/Li-Po and have drives offroad before if any help. :-)
I'm somewhat confused about all the settings of the RS Pro (but like the possibility of cause)
Kind Regards from Denmark
sasquatch is offline   Reply With Quote
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-05-2012 11:35 PM
////TEAM TEKIN FX PRO BRAND NEW///////// Warren Weaver R/C Items: For Sale/Trade 25 06-22-2009 07:21 AM
Team Tekin G11 Pro ESC azgreg R/C Items: For Sale/Trade 2 05-25-2008 06:12 PM
Factory team T4, Team Tekin new G-10 pro speedo icemandolmite R/C Items: For Sale/Trade 2 03-11-2007 04:26 PM
Team Tekin G11 Pro's DustinR R/C Items: For Sale/Trade 4 01-17-2007 06:38 PM
