Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 10-06-2008, 09:00 AM   #316
scootr117's Avatar
Originally Posted by scootr117 View Post
I was hoping to get in the web site to answer this question ,but for some reason it's down. What roll out (1-12th scale) is recommended for the 17.5 redline brushless motor? I will be using one this weekend as a loaner...wouldn't want to cook it...
I didn't get to use the Redline. The sensor wire plug hits the Pod on my REV4. tried several different clock positions with no luck.
Scooter EXperimental
RK Designs
CD SuperPro Motors
Mike Pulfer is my HERO....
scootr117 is offline   Reply With Quote
Old 10-07-2008, 08:28 PM   #317
losithrasher's Avatar
whats the diffrence beetween the rs and rs pro? is it just the motor limit?
ONE THINGS FOR SURE ABOUT THE STINGER, NOTHINGS FOR SURE!
losithrasher is offline   Reply With Quote
Old 10-14-2008, 01:58 PM   #318
Trader Rating: 75 (100%+)
The pro actually has a bigger case. I think the footprint is the same size though.
MUDVAYNE is offline   Reply With Quote
Old 11-02-2008, 04:55 PM   #319
Trader Rating: 126 (100%+)
I have an R1 and can not get it to calibrate to my DX3R!!
I bind it nad all seems well, steering works.
I go into calibration, it setects neutral to start, I then go full throttle and it detects that, and then full brake and it detects that but when I go back to neutral it just flashed the 3 middle lights.... I wnated to use it today but all I got was frustrated...
Any help would be appreaciated....
tyreguy is offline   Reply With Quote
Old 11-03-2008, 03:23 AM   #320
iirc, whenever a tekin speedo flashes three led's like that it's saying that the neutral range is outside of the expected range. try widening your neutral range and see if that helps.
Sabin is offline   Reply With Quote
Old 11-03-2008, 03:29 AM   #321
How do you widen the neutral range?
Old 11-03-2008, 10:43 AM   #322
Team Tekin
Tekin Prez's Avatar
However we never flash the middle 3 leds? Bottom 3 or top three if we do not see nuetral during initialization. We do flash the middle 2 if we are rebooting.
What does it do when you turn it on now? Initialize like normal and respond to throttle/brake correctly?
Tekin Prez
Tekin Prez is offline   Reply With Quote
Old 11-03-2008, 11:28 AM   #323
radio_car_racer's Avatar
R1 Sensorless ESC
will be using in a 2wd with 6.5, 7.5bl motors
what settings should I use for intitial setup please
have the hotwire to programme it
radio_car_racer is offline   Reply With Quote
Old 11-04-2008, 02:22 AM   #324
according to the R1 manual, it's NW. LED4.
Old 11-06-2008, 12:18 AM   #325
Originally Posted by radio_car_racer View Post
R1 Sensorless ESC
anyone?
Old 11-06-2008, 10:42 AM   #326
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Hey,
If i was running the 6.5 I'd start out with my timing around 70, TP 3, NW 10, BS 50, and PC around 80.
For 2wd the 6.5 is a lot of motor for 2wd unless you have gobs of traction. I'd start out with the 7.5 first, same settings.
Something about winning attracts losers with opinions......
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, B-fast, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-06-2008, 03:16 PM   #327
Originally Posted by Randy_Pike View Post
Hey,
Cheer's
got gobs of traction, I'm in the UK
Old 11-06-2008, 03:26 PM   #328
Hey,
Randy,
current settings are here
http://www.rctech.net/forum/attachme...ro-hotwire.jpg
Old 11-07-2008, 08:59 AM   #329
Team Tekin
Randy_Pike's Avatar
I'm happy with those! That's right around where I recomended.
You can play with more timing if you wish, just watch the motor heat.
Old 11-07-2008, 10:33 AM   #330
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
With the timing on the motor in the middle, a 49-81 with 1.70 tires is a good starting spot on a track 90 x 50. on a smaller track, 80 x 40 I was at 47-81 with 1.65 tires. Motor temp of 140 ish was good.
-Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-06-2012 12:35 AM
////TEAM TEKIN FX PRO BRAND NEW///////// Warren Weaver R/C Items: For Sale/Trade 25 06-22-2009 08:21 AM
Team Tekin G11 Pro ESC azgreg R/C Items: For Sale/Trade 2 05-25-2008 07:12 PM
Factory team T4, Team Tekin new G-10 pro speedo icemandolmite R/C Items: For Sale/Trade 2 03-11-2007 05:26 PM
Team Tekin G11 Pro's DustinR R/C Items: For Sale/Trade 4 01-17-2007 07:38 PM
SEO by vBSEO 3.5.0
