Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 02-22-2006, 06:43 PM   #16
FBJ's RDX's Avatar
Originally Posted by TeamTekin
Still concerned on the run time. Is the motor hotter when dumping in 4min? 2 plus minutes of missing juice is going somewhere... thats a bunch. The only way we can dump that quick is to over gear a low wind???? like 6x1 and the motor and speedo get really hot. We just pass the power... we do not eat it. How is the coast in nuetral and brake strength?
Tekin Prez
I have 3 Motors that I use, they are all by DC Motorsport, 8x1 Ti3 (2pcs) and 8x1 DC Cobalt. I am pretty much spot on with the gearing. Drive Freq setting is at 7250 and the Brake Freq is at 15000. Current Limiter is set at 40%, anything higher will surely dump at 4min. Min Brake and Drag Brake are set at Default.
Originally Posted by AxionJacob
how much timing do you have in the motor? I'm assuming that you are running mod touring
I run the static timiming of my DC motors at 12*, they are all 8x1. I get the same result from each motor. I dump at 4min when I set the current limiter anything above 40%.
FBJ's RDX is offline   Reply With Quote
Old 02-23-2006, 09:07 AM   #17
Team Tekin
Tekin Prez's Avatar
Thats pretty conclusive. If those exact same setups go 6min with other speedos we better see that unit. The anything above 40lim is odd as well. It is not a switch.. it is a dimmer.
Tekin Prez
Tekin Prez is offline   Reply With Quote
Old 02-23-2006, 09:50 AM   #18
Super Moderator
Trader Rating: 17 (100%+)
yeah you might have just gotten a bad one. I'm sure they will help you out. Oh and if you can...try to get a 10 or 11 turn and see if it makes your lap times go up or down
Tekno | JConcepts | RRP | LutzRC | BOOM RC
Bob Barry is offline   Reply With Quote
Old 02-28-2006, 05:20 PM   #19
Originally Posted by StephenSobottka
Jim and myself have taken it upon ourselves to start a Tekin thread for any questions you may have of the company or its fine products. Enjoy!
Stephen: This is cool! Thanks for starting the thread. Hope Jim can keep up with it!
LadyBoss is offline   Reply With Quote
Old 03-01-2006, 01:54 PM   #20
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
*salutes* NP Sherri!
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 03-08-2006, 03:45 PM   #21
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Ive got a g10 pro I picked up second hand. What would I need to do, to see about sending it in for repairs? It does not go into setup. It seems to run fine wihtout a load, but when I put the car down it acted like a dead battery.
Thanks,
Billy
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 03-10-2006, 08:31 AM   #22
Team Tekin
Tekin Prez's Avatar
Checked the current limitor? Did you do a full factory reset by pressing both buttons for 3 sec? ( The motor runs up to full 3 times.. be ready) You can always send an email to support@teamtekin.com and figure it out or fix it.
Tekin Prez
jcampbell@teamtekin.com
Smarter, Smaller, Faster....
www.teamtekin.com
Old 03-10-2006, 08:39 AM   #23
Cool, I will give that a try tonight. Thanks for your time.
Maclin | VP-Pro USA
Old 03-10-2006, 01:45 PM   #24
Cool, best set this thread to subscribe then, help all you guys (and gals Sherri) out there.
I would agree with Jim about the ESC dumping at 4 mins, there must be an issue somewhere if the same setup works fine on other ESC's, if anything, the G11 will give you more grunt for the same juice, so when it is working right, you might find you can either gear down or have some serious speed down the straight. Rubber tyres on carpet indoors I can sping all four up coming out of corners in 19t....
DA_cookie_monst is offline   Reply With Quote
Old 03-10-2006, 10:00 PM   #25
What are the differences between a g11 and g11 pro?
Maclin | VP-Pro USA
Old 03-11-2006, 02:10 AM   #26
The FET package, the Pro has better (less on power resistance) than the stock G11.
Old 03-11-2006, 09:19 AM   #27
Team Tekin
Tekin Prez's Avatar
The G11 is a pro level RTR. No solder post.... requires no soldering. Comes pre-wired with standard battery connector and bullet connectors for the motor. Can be used as a 3 wire setup also just like the pro.
Tekin Prez
www.teamtekin.com
Old 03-11-2006, 01:49 PM   #28
rbboy's Avatar
Send a message via MSN to rbboy Send a message via Yahoo to rbboy
Tekin Prez: my G11 PRO is acting weird.. when i use my DC motors 6x1 & 8x2 the throttle sort of delays the current but if i pull slowly it is normal.. what are the best settings for mod, 19t and 27 stock?
www.xtremerchobbiesph.net
rbboy is offline   Reply With Quote
Old 03-12-2006, 01:49 AM   #29
pumbaapig5's Avatar
Hey not the prez, just a team driver.
I run my g-11 at the lowest setting for stock. and default for both 19 and mod.
Never had a brush wear problem or any heat issues.
Matter fact I was able to go up one tooth on stock.
Enjoy, thanks Mike
Cristina Smith-Turner, MY Dragon above shall always watch over me....
Frank Jarrells, My Friend, "Their just toy cars. Mike Relax and enjoy..."
TEAM CODY DENNIS... "Simply Believe"
TEAM VENOM. Batteries that Last.
Team FAT and the Furious and Turners the Furious. Right Adam?
pumbaapig5 is offline   Reply With Quote
Old 03-18-2006, 03:09 AM   #30
Default Recommendation?
Hey all, just getting back into R/C after almost 15 years out. (I remember anxiously awaiting the release of the stealth tranny for my RC-10, that's how long...)
I've got a TT-01 that's mostly a basher for me and my 6 year old to run in the parking lot, but lately I've been thinking of running it in a couple of races. I'm looking for recommendations on a new ESC. I'm looking for something reasonably priced, and I don't anticipate running anything much wilder than probably 15T or so - it's just for fun, after all, and I don't want to have to swap motors when it's my son's turn to drive.
Any thoughts?
=P
subchop is offline   Reply With Quote
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-06-2012 12:35 AM
////TEAM TEKIN FX PRO BRAND NEW///////// Warren Weaver R/C Items: For Sale/Trade 25 06-22-2009 08:21 AM
Team Tekin G11 Pro ESC azgreg R/C Items: For Sale/Trade 2 05-25-2008 07:12 PM
Factory team T4, Team Tekin new G-10 pro speedo icemandolmite R/C Items: For Sale/Trade 2 03-11-2007 05:26 PM
Team Tekin G11 Pro's DustinR R/C Items: For Sale/Trade 4 01-17-2007 07:38 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Brian John
SEO by vBSEO 3.5.0
