Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree9Likes
Old 10-11-2007, 10:33 AM   #211
Regional Moderator
Exterminator's Avatar
Default FX series speed controls are now available
If you didn't know already the FX's are out and winning races. These are the smallest brushed speed controls available and you gain in performance over anything out there.
Smoother more efficient and easier to fit into any chassis.
Retired from sponsored racing, Now just having fun.
Exterminator is offline   Reply With Quote
Old 10-20-2007, 09:15 AM   #212
Hey guys....
I am currently updating all my electronics and am looking hard at brushless ESC's to replace my old GTB. The R1 pro looks great but I have a few Q's
*what kind of thermal limit does the ESC have (with no sensor wire I guess the motor temp is irrelevant).
*What's the internal resistence/current limit
*How does the speedie perform with the usual sensorless problems like "cogging" off the line and no drive when the chassis rolls backwards (you can always count on some idiot to hit you when you are having a flyer!)?
Cheers guys...
Dragonfire is offline   Reply With Quote
Old 10-20-2007, 09:22 AM   #213
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
It was nice to meet the team yesterday at the iHobby show. The new R1 brushless setup looks great, and I look forward to seeing it released. Hopefully the "geek talk" was kept to a minimum for the non-geeks at the booth .
Thanks for taking the time to show us the products.
Jimmy
g12314 is offline   Reply With Quote
Old 10-20-2007, 09:58 PM   #214
Team Tekin
Randy Pike's Avatar
If you're running 6 cell the thermal limit is up there. I can't release the temps that I know without speaking to Jim first. I do know that we were higher then Novak. Seriously though this shouldn't be an issue unless you're running a super low turn motor on high bite carpet with no airflow what so ever on the unit. In other words, as long as you don't shrink wrap the R1 or stick it in a balloon you should be ok.
Internal resistance spec on the R1 PRo is:
0.00005 Ohms (brushed fwd mode)
0.00015 Ohms (brushless mode)
0.00015 Ohms (brushed fwd/rev , no motor limits while using 4 to 9 cell sub c.
R1 spec's are:
0.0001 Ohms (bushed fwd mode)
0.0003 Ohms (brushless mode)
0.0003 Ohms (brushed fwd/rev mode) again 4 to 9 cell sub c.
Both spec's also at 3s lipo.
As I'm sure you've heard or found every system is different with cogging,etc. I know that there are certain motor combinations what worked better the others.
The worst condition was when rolling backwards off throttle it takes a brief moment to get started again. This isn't so much a cogging feel as it is a slow start. The car I was testing with was a Fk05. If I was tapped around and it did roll back it took less then 6 inches or so to get back up to speed. The starts were really good. You could cause a bad start if you REALLY tried but you had to be a dummie to do it. If you rolled up to the grid like you normally would the start is awesome. Lanches off the line are great. The higher turn motors like the 10.5's and 13.5's are the worst of the bunch but again we're talking literally inches of a full throttle a main start.
Remember that the R1's are "sensorless" but we ARE sensing the position. We're using the windings for our "sensor."
One of my favorite combo's was the Orion 4.5 motor with the R1 out of all of the "non tekin" motors I tested. Second to that was Novak's 5.5r motor. Super smooth and great all around power.
I'm sure everyone will settle into their favy's when you get to drive 'em!
Randy Pike is offline   Reply With Quote
Old 10-21-2007, 09:00 AM   #215
Cheers randy.. thanks for the feedback...
I currently run all novak 3.5-5.5 but plan to run only 3.5 under 5cell.
I also use a "launch control" type setup on my radio to give perfect starts every time so I think this will eliminate the cogging off the start anyway.
Will they have a heatsink option or will it come with a heatsink in the pack?
Cheers...
Old 10-21-2007, 10:53 AM   #216
Team Tekin
Randy Pike's Avatar
The R1 series doesn't require a heatsink. The solder posts act as a very efficient heat sink. So in theory if you did need to cool down your R1 you can either fan the solder posts or turn the r1's position so that it receives some air flow to cool it down.
I personally never found a need for a fan. The only time where I did run one was outdoor asphalt TC running 6 cell. Even then I never did thermal it I simply ran it as a precaution.
Old 10-21-2007, 11:08 AM   #217
I have the FX-PRO's that I will be running this carpet season and it is incredible to note that even though it has the most fets ever in a speed control it still only takes up the same footprint as a micro spectrum Rx!
Thanks Tekin!
jeffb is offline   Reply With Quote
Old 10-22-2007, 09:13 AM   #218
Team Tekin
TY@TEAMTEKIN's Avatar
Thanks Tekin!
We're all about innovation!
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 10-23-2007, 08:43 PM   #219
Glowster21's Avatar
Trader Rating: 116 (100%+)
Any word yet on R1 shipping? Loving my FX Pro but still have the brushless twitch.....I know it will be well worth the wait
Glowster21 is offline   Reply With Quote
Old 10-25-2007, 08:27 AM   #220
Regional Moderator
Tekin Innovation for the Racing Nation!
Old 10-28-2007, 03:21 PM   #221
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Question... How is the Novak 13.5 brushless running with the R1pro? Cause thats the motor I would be using. Starting to look into the brushless ESC's and Im very interested in R1pro.
TL_XXX-S_racer is offline   Reply With Quote
Old 11-02-2007, 07:58 AM   #222
JB_catricala's Avatar
hey guys
i ran the new fx this last weekend at the the halloween classic and i loved it, it is so small and lightweight but still dleievers the power when needed. and after seeing the r1 go in dave arnolds car i can't wait for that either.
Hi
Serpent
SMC
AKA
FarmCats
JB_catricala is offline   Reply With Quote
Old 11-02-2007, 02:23 PM   #223
Kropy's Avatar
Send a message via AIM to Kropy
JB ~ Welcome to the team!!!!!
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 11-04-2007, 10:55 PM   #224
JB congrats on the Tekin deal. Welcome to the team!
Old 11-05-2007, 02:02 AM   #225
tc3team's Avatar
Welcome to the team JB
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-06-2012 12:35 AM
////TEAM TEKIN FX PRO BRAND NEW///////// Warren Weaver R/C Items: For Sale/Trade 25 06-22-2009 08:21 AM
Team Tekin G11 Pro ESC azgreg R/C Items: For Sale/Trade 2 05-25-2008 07:12 PM
Factory team T4, Team Tekin new G-10 pro speedo icemandolmite R/C Items: For Sale/Trade 2 03-11-2007 05:26 PM
Team Tekin G11 Pro's DustinR R/C Items: For Sale/Trade 4 01-17-2007 07:38 PM
