Oh #%@!! What did I do to my SMC Lipos?
Ok, I think I just seriously bit the weenie on this one. I just finally got done upgrade my Savage Flux with a new Spektrum DX 2.0 with some Proline Badlands and Velocity dish wheels. I programmed the DX 2.0 as per the usually HPI way and made sure the EPA's were at 125% and the throttle and steering where as even as possible without using trim. I kept the gearing stock at 20/44.
I"m using SMC Sport Max 6000mAh 28C hardcased batteries which have been awesome batteries up until this point. I've been using a Triton 2EQ with balancer at each and every charge and iv'e had the LVC set from 3.0v to 3.2v using the Castle link.
Today was my first day running the new truck and I kept it simple and was just running it in average grass height at a variety of speeds testing out the new tires and rebuilt shocks. I kept checking the temps and I didn't feel the motor, ESC or batteries were getting dangerously hot.
It was working good for around 15 or so minutes when I noticed it started to loose power pretty quickly, more then it used to.
So I shut it down and brought it inside and I about had a cardiac arrest when I took out the batteries that were very warm to the touch and had damn nearly puffed out of the hard pack casings!!
I immediatly put them outside to cool off and hopefully not explode, so I haven't taken a voltage reading on the charger but the LVC was set at 3.1v and it didn't kick in at any point, I just noticed a loss in power sooner then I expected.
Anyone please give me incite or suggestions on what the hell went wrong here? I'm pissed that just ruined $190 worth of batteries and I don't know how or why!
EDIT: Added photo of voltage test results for both Lipos
bump for a concerned customer!!!
I didnt want to double post, from the off road thread but I will share the photos from this past week.
Truth be told... I would say those packs are done for..
They will continue to work, as you've noticed, they're still alive. but when a Lipo has puffed liked that it means they've been 'stressed'. You could continue to run them, but they may go up without warning and you could be up for a completely new car, motor, esc etc etc..
EDIT: btw.. I set my LVC to 3.2v (Auto), but I rarely run to LVC. I usually stop when I notice a decrease in perfomance.
If you really want details, here are some photos of the grassy area I was driving on when this occured. Sure as hell don't look like it would cause my batteries to fry like that but then again, anythings possible at this point I guess.
Strange, I have the same problem
Same batteries, same problem BUT in my case they were in my boat (SuperVee 27). The ESC is rated for 45A so way below the maximum Amp the batteries can give (168A). They were like those in top of thread (not allowed to post pics right now) after a 7min run. ESC was at 88°F, motor at 102°F and batteries around 100°F (the temp gun is not calibrated for this). I have around 10 runs with this boat and may be 20 runs on my Flux, something like 30 runs max on those packs. After 1 hour cooling, they went back to normal (deflated) and reading was around 7.7v. I tried to charge them (very carefully in a lipo sack) and was able to pump 4500mAh. But now I'm not sure if I want to put them back in my vehicle.
There is something very wrong with those cells. I will ask SMC about that.
I ran these same batteries in my losi 8T-e with a mamba monster steup(same as flux) and never had a problem... I think mamba sayts the motor/esc can pul 180 continous amps???
Ive read alot of places the flux's are gear to the moon out of the box and can fry esc/motors etc... try buying a larger spur gear or a smaller pinion gear
oh btw i would contact SMC
http://www.smc-racing.com/contact.html
Alex
Alex
R/C Tech Elite Member
Alex
Alex
1. The MMM is rated to 120amps continuous not 180. That is LESS than the Traxxas VXL ESC which is rated to 200 amps.
2. The Savage Flux is NOT geared to the moon out of the box, if anything it's a tad undergeared and can demonstrate the "hot motor, cool lipo, cool esc" telltale signs if run on tyres any smaller than stock. Also an undergeared truck would usually stutter on takeoff struggling for amp draw, not be able to do standing backflips!
And further to this, isn't it curious that SMC has yet to respond to this? Are they aspiring to be the next Maxamps?
To me it seems like dodgey packs, a quick glance through this forum shows that SMC packs seem to be a bit puff happy.
I don't know where you get your info but lets get this straight ok?
Notice how i said I think 180....
And look in ANY flux forum and everyone says theyre over geared out of the box...
Alex
