Go Back   R/C Tech Forums > Company/Manufacturer Forums > SMC (Superior Matching Concepts)
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-15-2009, 08:14 PM   #1
brushedmaxx2's Avatar
Exclamation need an answer plzz before thur. night
do you have to do any work to these batts running such as soldering cuz it says assembeld http://www.specpointbatteries.com/in...p?productID=14
brushedmaxx2 is offline   Reply With Quote
Old 07-15-2009, 09:14 PM   #2
Moogumby's Avatar
I think because it says
"Home / SPC/EnerG 4600 mAh Matched Racing Cells & Packs. Please allow a minimum of 5 to 7 days after ordering for battery pack construction & testing.
that they are assembled.. you even pick the type of connector you need when you order them.
Traxxas Slash | Tamiya Boomerang | Team Losi 8ight 2.0
Home Track:Area 52 Rc Ranch Raceway & J&S Hobbies Plus Raceway
Moogumby is offline   Reply With Quote
Old 07-16-2009, 07:27 AM   #3
OG RC 10T's Avatar
Trader Rating: 22 (100%+)
Besides the shipping taking 5 to 7 days, they are also out of stock.
Usually these cells are individual and you would have to solder them together with battery bars, pos and neg wires, and a connetor such as a deans plug.
The site says assembled and pick your connectors, though adding connectors raises the price too.
If your not good at soldering, and or do not have a high quality soldering iron, I would not attempt building a pack on your own. Overheating the cells, and or not soldering them just right, can damage the batteries. Just FYI.
Original RC 10T. Bl eRevo, Tekin RX8.
OG RC 10T is offline   Reply With Quote
Old 07-16-2009, 11:07 AM   #4
ok.. so heres what i'll prob get... do these need any speacial charging beside a first slow charge.
http://www3.towerhobbies.com/cgi-bin...?&I=LXULS6&P=V
Old 07-16-2009, 11:38 AM   #5
OG RC 10T's Avatar
No, First charge should be a slow charge at 2 amps, cycle the battery once or twice than charge at the rate recommended on the pack.
Old 07-16-2009, 11:58 AM   #6
i'm srry battery newb. but wuts cycle mean again
Old 07-16-2009, 07:11 PM   #7
myrxseven's Avatar
One cycle would be charge and a discharge.
CRC Gen XL 17.5 1s Lipo
Spektrum l Novak l Tekin l SMC l Jaco
myrxseven is offline   Reply With Quote
Old 07-16-2009, 08:33 PM   #8
okk. but by discharging i could just run it slowly in my truck right cuz i have a prophet sport chager
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
