general lipo question
I've notice a lot of 5000 or more mah batteries are wired 2s2p my question is how does the balancer balance the 2 cells that are wired in parallel? if I'm understanding correctly on how balance works a 2s2p battery will never have a true balance due to the wiring configuration?
Company Representative
Since the 2 cells are in parallel they become one cell so they will both charge to the same voltage.
The reson why higher capacity packs use a 2P setup is mostly because of the limits in hardcase size and also a Lipo cell can't really be thicker than 8.5mm which limits it's capacity.
Danny;
Do you have anything coming soon that a World Gt can use a 13.5 motor with and be competitive against a 4 cell pack.I tried with the single cell with no luck for as long as you have had the cell available.I can't switch to a different motor.Now I'm waiting for a lipo that will be competitive with a 13.5 motor against 4 cells
