Go Back   R/C Tech Forums > Company/Manufacturer Forums > SMC (Superior Matching Concepts)
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-07-2009, 02:03 PM   #31
Thanks for the reply, these packs have been good the couple times ive used them. Hopefully can I reach the 20 minute mark.
Associated FT rc10B4 tekin rs Redline 10.5
Associated rc18t Mamba 25 castle 6800
Mini e-revo, Bandit, Vendetta
supporting my LHS: wwnh.net
rc18/xxxt racer is offline   Reply With Quote
Old 06-11-2009, 09:48 AM   #32
What is the max continuous discharge rate for this battery? Burst? Is there a list with this info for all SMC batteries somewhere? Thank you !
Derry is offline   Reply With Quote
Old 06-11-2009, 09:53 AM   #33
Company Representative
Danny/SMC's Avatar
All our Lipos can do the C rate as the continous current. The burst is 2 times the C rate.
www.smc-racing.com
Danny/SMC is offline   Reply With Quote
Old 06-11-2009, 10:57 AM   #34
Sorry, I am a little confused. I meant in amps...Like my 6000 Max Amps lipo says 120 amp continuous rate. So does that mean your 6000 pack has 128 amp continuous rate?
Thanks !
Old 06-11-2009, 11:01 AM   #35
Danny/SMC's Avatar
To get the amps you multiply the C rate by the mAh. So for the 6000/28C it would be 168000mAh which equals 168 amps. The burst would be 336 Amps. This is what the pack can handle but if someone would want to use the pack at 168 amps the wires would need to be bigger and direct soldered.
www.smc-racing.com
Old 06-27-2009, 04:13 PM   #36
myrxseven's Avatar
So, I charged my 6000 up on wed night. Once charged I placed it in a Lipo bag fopr storage. On Friday when I got to the track and pulled the Lipo out it was puffed. This pack always had been pretty poochy in power. So im thinking that there has been something wrong with this battery from the get go.
CRC Gen XL 17.5 1s Lipo
Spektrum l Novak l Tekin l SMC l Jaco
myrxseven is offline   Reply With Quote
Old 07-06-2009, 08:24 AM   #37
myrxseven's Avatar
Just wanted to say what awsome customer service SMC has, and how prompt they are. Also want to thank SMC, and to keep doing what your doing.
Old 07-08-2009, 10:16 PM   #38
R-E-A-P-E-R-'s Avatar
What kind of runtimes are you guys getting with these. Anyone using them in a 1/8 scale setup or revo running 2 of them??
----- Caster EX-1 - Caster F8T - Caster ZX-1.5R - Caster F18 -----
---------------------------- TEKIN ------------------------------
R-E-A-P-E-R- is offline   Reply With Quote
Old 07-09-2009, 05:21 AM   #39
Trader Rating: 30 (100%+)
people need to uunderstand electricity better. and this applies to a lot of people because people ask "how many amps will i get, or how many amps with that give me??""""
the thing is, you dont get amps, amps are drawn.
and that is up to the wattage of your motor.
if you have a high capacity battery with a high c(not the drink) rating, and your motor is very low wattage, guess what? nothing special is going to happen.
if you all want to to truly know what your motor is pulling from the battery pack, then go buy an ammeter and place it on 1 leg of the motor while it is running. that will tell you what your amperage draw is. and i will promise, you will be dissapointed what you see. because the amperage will not match what you are hoping for and you will think it is low.
make sure the amp-meter is on the a/c setting for the brushless systems. because it is a 3 phase a/c circuit, not d/c. set it to dc for the brushed systems.
comedyman809 is offline   Reply With Quote
Old 07-09-2009, 12:14 PM   #40
drperry's Avatar
Send a message via AIM to drperry Send a message via MSN to drperry Send a message via Yahoo to drperry
The best way for this to work, is to get a data logger... It'll read power pulled by the ESC, but that'll be close enough...
Most hand held ammeters, aren't fast enough, and you won't get an accurate load reading while the vehicle is in the air.
RC18MT - Tekin FX/Stock motor
Yokomo MR-4TC SD CM Novak GTB/LRP X-11 13.5 brushless
Kyosho STR(R) - RB TM728 (btw, I HATE pullstart! lol)
Traxxas Jato - Castle Creations Mamba Max 5700kV cog-o-matic
drperry is offline   Reply With Quote
Old 07-09-2009, 02:39 PM   #41
good point, you wont be able to measure it white it is running on ground. how accurate is a data logger?
Old 07-09-2009, 04:09 PM   #42
drperry's Avatar
From everything I've read and heard, most systems are pretty accurate...
Definitely going to do better than most hand held multimeters or ammeters.
Old 09-21-2009, 03:41 AM   #43
Danny,
Will SMC make a 4s1p 6000mah hardcase version of this pack? Would really love that in my 1/8 buggy.
micke_b is offline   Reply With Quote
Forum Jump
XRAY T2’009 bola Electric On-Road 2064 Yesterday 10:37 AM
New SMC Lipo packs. Danny/SMC SMC (Superior Matching Concepts) 266 10-10-2009 11:02 AM
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 201 10-03-2009 12:28 PM
Which lipos C_Money Radio and Electronics 9 06-09-2009 08:25 PM
Which C rating to choose? ErikO Radio and Electronics 8 04-24-2009 02:33 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
