Go Back   R/C Tech Forums > Company/Manufacturer Forums > SMC (Superior Matching Concepts)
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-19-2002, 05:17 AM   #61
Company Representative
Danny/SMC's Avatar
I have left packs sitting for 6 weeks with no problems. So I can't really say that cycling them every two weeks makes a difference.
As far as NiMH not having memory I'm not convinced that this is the case.
To prove if your method has any advantages you would have to take another pack and treat it in a different way.
Testing is very tricky and time consuming.
www.smc-racing.com
Danny/SMC is offline   Reply With Quote
Old 04-22-2002, 07:18 PM   #62
Hi Danny
Just wanted to let you know, i purchased some SMC packs locally in Sydney Australia, and ran them on the weekend for the first time. I was really impressed, i had only been using the old version sanyo previously. I qualified second, in touring Mod, but in the final i unfortunatley dumped on the last corner, and was pipped for third on the line by 9 tenths.
We were really racing hard in the final with fastest times nearly 4 tenths faster than in qualifying, so am not too concerned with the dump.
I am going to have to play with different winds to get the best overall mix.
Besercoe is offline   Reply With Quote
Old 04-22-2002, 11:51 PM   #63
JohnA's Avatar
Besercoe
I'm based in Brisbane and have not been able to find any HV's by any of the more well known matchers, SMC, Orion, etc. the only ones I can find are matched here in Aus by Hobby Xpress.
Where did you get your SMC's, were they team or racer cells & how much were they?
Cheers
JohnA is offline   Reply With Quote
Old 04-23-2002, 11:42 PM   #64
vthondaboi's Avatar
Send a message via AIM to vthondaboi Send a message via Yahoo to vthondaboi
Default danny
Is it necessary to cycle the HV's and discharge them for storage to around 5.4 volts? I currently use 2000 sanyo nicads with my superbrain charger and an Indi 20 amp discharger that sets them to zero so I store them at zero with a gecko on them that drains it completely.
Kyosho ST-RR
Kyosho SP2
E-Flite Blade CX2 Heli
vthondaboi is offline   Reply With Quote
Old 04-24-2002, 08:17 AM   #65
Danny/SMC's Avatar
Besercoe: Thanks for the nice comments. If your HV's gave you plenty of power and you dumped you might want to drop the charge rate by one amp.
JohnA: We have an Australian Distributor called Scaled Adrenaline. The owner is Scott Hill.
www.smc-racing.com
Old 04-24-2002, 08:21 AM   #66
Danny/SMC's Avatar
vthondaboi: If you use your Hv's every week it's a good idea to bring them down to 5.4 volts. If you plan on storing them for a long period of time I would cycle them once every month just to be safe.
Visit our website for more detailed info on the HV's.
www.smc-racing.com
www.smc-racing.com
Old 05-06-2002, 05:58 PM   #67
MOTO's Avatar
Hi Danny! sent you PM!
MOTO is offline   Reply With Quote
Old 05-07-2002, 04:45 PM   #68
Danny,
I have a question for you about a cell that I damaged in a wreck last Saturday in my 1/12 scale Mod car. There is no voltage when I measure across the solder tabs, and there is voltage across each cell, except one of them. Is it possible to ressurect the dead cell, or should I give it a proper burial?
Thanks for your help.
Dave
Dave S is offline   Reply With Quote
Old 05-07-2002, 09:30 PM   #69
Danny/SMC's Avatar
If a cell reads zero it means it's an open circuit and there is nothing you can really do about it.
www.smc-racing.com
Old 06-03-2002, 01:05 AM   #70
Danny: do you use any temp cut off in your charging?
stik is offline   Reply With Quote
Old 06-03-2002, 08:28 AM   #71
Danny/SMC's Avatar
stik: No I don't believe that temp cutoff has any advantage over peak detection. I also believe that it's easier to make a mistake with temp cutoff.
www.smc-racing.com
Old 06-21-2002, 06:00 PM   #72
patelladragger's Avatar
Send a message via AIM to patelladragger
where can smc packs be purchased other than stormerhobbies?
patelladragger is offline   Reply With Quote
Old 06-23-2002, 08:51 PM   #73
Coxy's Avatar
R/C Tech Charter Subscriber
Danny, mate just thought I would give your cells a wrap. I was racing with a 8 x 2 on the weekend with a 26mm rollout. Wow quick, I was using SMC HV's and did another two laps after the race to show off the run time I had. Anybody wanting to know how good these cells are, let me tell you these are better than I thought.
Coxy.
Coxy is offline   Reply With Quote
Old 06-24-2002, 07:58 AM   #74
Danny/SMC's Avatar
patelladragger: Try homer@tiltyard.com
He's a great guy to deal with.
Coxy: Thanks for the nice comments and I'm glad our packs worked to your expectations.
www.smc-racing.com
Old 07-17-2002, 08:33 PM   #75
F1-Fanatic's Avatar
OK.. I think I may have a problem... I was charging my Sanyo 3000HV's last week at a race and peak charged the cells 2x.. well when peaking them the 2nd time I wasn't watching and the next thing I noticed I heard actuall popping sounds coming from the cells! Being relatively new to the hobby and having no idea what was going I disconnected the cells and let the car settle for a bit before running my main. The next day I went back to the track to do some laps and work on my car and the cells worked fine.. what was this popping and what did I do to the cells??? Did I kill their life by beating on them so badly?
How I charge/re-peaked the cells when I had the problem:
Turbo 35
Sanyo 3000HV (4 cell 1/12th scale config)
6 amps w/ a .05 peak detect
Thanks for any help/advice
F1-Fanatic
F1-Fanatic is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
