What's NEW at Street Revolution RC @Funan #05-46
#616
High Precision Gyro
Check out the High Precision Gyro available at Street Revo RC!!! Process Full Control of Where You Go, especially on high speed!!!
#617
Unbelievable Combo Deal at Street Revo RC!!!
Unbelievable Combo Deal at Street Revo RC!!! TRITRONIC 1/10 Waterproof Brushed 60A ESC + Hackmoto V2 Modified Brushed Motor at SUPER GOOD DEAL PRICE!!! For more information, check it out at Street Revolution Radio Control Concept Store
#618
Ultra Bright Front & Rear LED Light Kit
Light up your RC car today with the Ultra Bright Front & Rear LED Light Kit, super shine in the dark!!! Just like the real car...
Also available at S'wan Model & Trading Now!!!
#619
Aluminium Bearing and Motor Bearing Inner Size Measurer and Tester For 2-15mm
One of the must have barang in your tool box!!! Aluminium Bearing and Motor Bearing Inner Size Measurer and Tester For 2-15mm... Say goodbye to estimation or eyes straining!!! 100% ACCURACY...
#620
Overdose Divall 4WD Shaft Driven Car
Looking for a superior RC drift car?!? Check out the Overdose Divall 4WD Shaft Driven Car... Professional designer built to maximize the driveability and adjustability... High torque high power...
#621
Limited Edition - Tamiya TB EVO.6 Chassis Black Version
New Arrival...
Great Performance, New Colour Scheme! Check it out at Street Revo RC today!!!
The pinnacle of Tamiya shaft driven 4WD, the racing TB EVO.6 chassis now comes in this limited edition version with black anodized aluminium parts for a menacingly fast look. This high performance chassis utilizes a double deck layout with 2.0mm upper and 2.25mm lower carbon fiber decks for an alluring combination of excellent rigidity, and lateral flexibility during cornering. Both the mount for the horizontally positioned left-side motor and also the center bevel mount have been incorporated into an integrated aluminium piece, thus improving gear mesh and heightening drivetrain efficiency. The drivetrain utilizes front direct-drive and a rear gear differential setup. High-spec parts such as large capacity TRF short dampers, TRF418 suspension arms and aluminium suspension mounts come as standard.
#622
Limited Edition: Tamiya TB Evo.6 Chassis Kit (Black Version)
23/04/15: Limited Edition: Tamiya TB Evo.6 Chassis Kit (Black Version) available now!
#623
12AWG Transparent Wire 1M (Red/Blue)
New Arrival... Check it out at Street Revo RC today!!!
Features:
• For: Soldering
• Material: Silver Silicone Wire
Specification:
• Construction No. x 0: 680/0.08 mm
• Diameter: 2.48 mm
• Thickness: 1.0 mm
• Outer Diameter: 4.5 mm
Technical Data:
• Nominal Voltage: 300V or 600V. (It is well-suited for Radio Control Cars which require the standard of 0.1 - 24V.)
• Temperature Rang: -60¢J~80¢J
• Outer Diameter Tolerance: +/-0.1mm
• Test Voltage: 2000v
• Conductor: Tinned Copper
• Insulator: Silicone
Features:
• For: Soldering
Specification:
• Diameter: 2.48 mm
• Thickness: 1.0 mm
Technical Data:
#624
New Arrival: Yokomo Off Road Buggy YZ-2
New Arrival... Start your off road adventure with Street Revo RC today!!!
Yokomo Off Road Buggy YZ-2:
- Super-low center-of-gravity motor mount and gearbox
- Variable skid angles (0, 2.5, 5 degrees) by replacing the bushing of the front hub carrier
- Variable toe-in and skid angle by replacing bushings of the rear suspension arms
- Newly-designed aluminium steering rack
- Aluminium rear suspension mount
- Aluminium front upper arm mount
- Aluminium front suspension arm mount support
- One-piece aluminium main chassis
- Support for both stick and shorty LiPo batteries
- Carbon graphite battery plate
- Dual-pad slipper clutch
- Aluminium front and rear hex wheel hubs
- 4mm-thick carbon graphite front and rear shock towers
- Low-friction, hard-anodized shock cylinders
- Newly-designed forward-cabin racing body
#625
Yokomo Off-Roader T-Shirt!!!
Hey guys, check this out! Are you interested? If so, keep calm but act fast!!! Pre-Order the YOKOMO OFF ROADER T-SHIRT by 8th May 2015 to ride on the free name customization service on sleeve at just S$20 only. Please kindly note that order is only confirmed upon payment received (cash term payment only)!!!
#626
StreetJam OTA-R31RS COMBO DEAL - 3 Belt Drive System Ready Kit...
Calling for all the RC Drift enthusiasts whom like to start the hobby!!! Check out this StreetJam OTA-R31RS COMBO DEAL - 3 Belt Drive System Ready Kit...
Comes with more advanced electronics*:
- 3 Channel 2.4GHz F.H.S.S.-2 Surface Radio System
- Sensorless Motor
- Brushless Electronic Speed Controller
- Fast Charger
- High Capacity NiMH Battery
*more advanced electronics as compared to electronics available in RTR set
#627
Limited and Special Edition of Miku Racing 2014 Off-Road Buggy
MID WEEK IS HERE!!! For those whom have missed out the purchase of the Limited and Special Edition of Miku Racing 2014 Off-Road Buggy, is the great chance once again, wait no more and hurry down to grab the last few units available in Singapore. Definitely worth to be one of the collectable!!! Cheers...
#628
Ultima RB6 Racing Buggy RTR
Looking to start a new hobby for the coming long weekend? Check out this Ultima RB6 Racing Buggy in Ready to Run version!!! Everything needed are inclusive and offering at an attractive price. Is time to go outdoor and have some sun!!! For more information, check out at Street Revo RC today!!!
#629
Happy Labour Day - Business Operation Hours (please note)!
Dear valuable customers, is Labour Day holiday tomorrow!!! So looking forward man... Please kindly be informed that Street Revo RC will operate from 11am - 6pm tomorrow, 1st May 2015. Sorry for any inconvenience caused and thanks for your attention! Have a great long weekend ahead, cheers...
#630
"Rest is the sweet sauce of Labour" - Plutarch | Happy Labour Day!!!
Happy Labour Day guys!!! Enjoy your long weekend this 1st May!!!
Cheers...
*P.S.: Please kindly be reminded that Street Revo Rc will operate from 11am - 6pm today!!! Sorry for any inconvenience caused and thanks for your kind attention!!!
Cheers...
