Tamiya Asiacup Qualifying 2005 (singapore)
#781
Hi Guys,
For those who do not have the time to go test till Sat.
I've drawed a simple not to scale rough layout of the track.
Hope this helps.
Hope this helps.
#783
Originally Posted by Ben.C
Hi Guys,
Hope this helps.
Hope this helps.
Ah Ben, No use lah... with the babes around, you think all cars will drive properly??
Best advice, bring your GF or wife down then your eyes will concentrate on the car
2nd best advice, replace ball diff with gear diff as its likely your balls will go loose....
#784
BEST ADVICE EVER YET!!!!!
#785
Better advise, bring your own race queens to distrace other drivers
#787
yo..
forget wat i have sae...
#788
Go there happy happy, come back angry angry....
GT2 run 5 times and only got 2 results!! Every run have to clean all the stuff out.
If TAC next month gonna screw up again, don't ever expect to see TAC to be held locally again!
#789
#790
Originally Posted by zax
WA LIAO a...The expo carpet track just like kana sai...so many fur cock up at the car..We need to waste time to take out the fur...And the fur so strong tat spolit my ball bearing...now i need to change new ball bearing... waste of money and time..
#791
Here is a suggestion "fustration is self inflicted" perhaps a little tolerance and some constructive feedback could go a long way to help make the event better.
#792
Originally Posted by viper1
Sigh.....if no race complain....got race also complain. No one can guarantee the full stability of a window operating system. The system that stargek used is no exception.I believe they have replaced the laptop and you should see the end of the transponder errors.
I believe suggestions to replace the laptop were already there in the first TAC race this year, as we had to face quite a few reboots in the race alone and restarts. This is actually an "old" problem that happens almost every TAC series race.
Most of us took it in our stride.
However for this weekend's particular race, since points from this race are compulsory for the overall series points, a setback in this race would result in some people not being able to qualify for the Asia finals. Case in point, some people have had to retire halfway during their qualifying heats because too much carpet fuzz accumulated in their car's drivetrain and the car just refused to move after that. Hence, there is an element of uncertainty which one can attribute to bad luck, but it is surely an element which could have been controlled though now its too late and we'll have to let the magic carpet decide who makes it thru to the finals in the most important race of the series.
#793
hopefully tomolo will be smooth and end early...
#794
sounds like someone indeed had problems with balls, i mean ball bearing. Sorry guys, i couldnt resist. please bear with me :X
Have all change to gear diffs????
#795
Well some of the lucky ones just change 1 ball bearing but for some ahh think more than 1 esp those using blue seal bearing.
But overall the race was ok only the transponer and computer problem have not being solve and it keeps on having problem and having to restart again sian.
