for savage :-
TSAV1049T Titanium main gear 49T
SSAV1049T Hardened Steel main gear 49T
SAVSCP Slipper Clutch Pad 1pc
TSAV1160 Titanium tie rod with ball link 2 pr
TSAV1160/BE Titanium tie rod ball link 8 pcs
SAV1011 Alloy Front/Rear gear box
SAV1012 Alloy Front/Rearbulkhead
SAV1012A Alloy Front/Rearbulkhead gear box brace 1 pr
SAV1014A Alloy Front/Rear chassis mount
SAV1016 Alloy 3mm main Chassis
SAV1019 Alloy front/rear C hub
SAV1021 Alloy front/rear steering block
SAV1025 Alloy Diff lock
SAV1026 Alloy fuel tank mount
SAV1028 Alloy Front/ rear adjustable damper plate
SAV1032 Alloy front/rear body post
SAV1038 Alloy Center Gear Box
SAV1039A Alloy Brake Disk Adaptor
SAV1048 Alloy bearing Steering
SAV1048 Alloy bearing Steering's bearing 4pcs
SAV1052 Alloy front/rear center arm lock
SAV1054S Alloy Front/rear adjustable upper arm (steel tie rod)
SAV1055 Alloy Front/rear adjustable lower arm
SAV1080 Alloy Engine Mount with screws
SAV1088 Alloy fuel tank cap
SAV1089 Alloy fuel tank protector
SAV1305 Alloy air filter with extra sponge fits 21-.28 engine
SAV1311 Alloy Font/rear roll bar set
SAV1311/BE plastic ball ends for roll bar spare
SAV1325 Alloy fuel valve mount
SAV1331F Alloy front skid plate Can be use front or rear
SAV1331R Alloy rear skid plate
SAV1332 Alloy center skid plate
SAV1333R Alloy rear wheelie bar with rims and tires
SAV1335B Alloy front aminal bumper guard
SAV1336B Alloy rear aminal bumper guard
SAV13170/8 Alloy damper 8pcs 1 set (come with boots and screws)
SAV13170SH Stell Shaft for SAV13170 Damper 1pr
SAV13170/SC/4 Alloy upper &lower spring cap for 2 dampers
SAV13170/AD acc inside the damper (1pr set)
HSAV1619T Alloy 7075 clutch gear 19T + clutch bell
for savage x :-
SAX1012 ALLOY FRONT/REAR GEAR BOX WITH SCREWS 1 ASSEMBLE SET
SAX1014 ALLOY SUB-CHASSIS - 1PR
SAX1016B ALLOY MAIN CHASSIS MOUNT WITH SCREWS - 1PR SET
SAX1028 ALLOY Front/Rear Shock Tower 1PC
SAX1052 ALLOY FRONT/REAR GEAR BOX ARM BULK - 3PCS
SAX1330F ALLOY Front Bumper Guard
SAX1330R ALLOY Rear Bumper Guard
SAX1332 ALLOY center skid plate
SSAX1049T Hardened Steel main gear 49T
so very sorry for the long list...
pm me for best price, give me your email adds if u need pictures... cheaper than ebay...
