Go Back   R/C Tech Forums > International Forums > Singapore R/C Racers
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-02-2005, 05:04 PM   #16
firegarden777's Avatar
Originally posted by 4Wheeler
Yo dude,
Congrats on getting your MT. I'm pretty sure u'll have fun bashing it around...
And happy cleaning... :L
i'll join u when I get my emaxx!
Eh Emaxx cannot make it lah.
Just kidding!!!
You running dual brushless setup???
firegarden777 is offline   Reply With Quote
Old 01-02-2005, 05:30 PM   #17
Yo dude,
Just kidding!!!
Old 01-03-2005, 08:18 AM   #18
civiclized esi's Avatar
Ran in my 2nd and 3th tank today the engine temperature is still on the high side after serval settings manage to bring down the temperature have problem modding the throttle linkage and throttle return spring help needed any suggestion
civiclized esi is offline   Reply With Quote
Old 01-03-2005, 03:35 PM   #19
How are you setting up the throttle linkage? For the throttle return spring, you can try making a small hole at the side of the roll bar and connect the spring between the rollbar and the carb.
How you managed to run in your engine with all this heavy rain?
Old 01-03-2005, 03:48 PM   #20
Post Run in tempreature
Good day to all
Would like to check with you all gays what kind of temperature did you get during the run in? as for me i am getting about 95 to 100 'C .The only problem that i have is the one way bearing at the starting side alway give way as i am useing a rotor starter for my savage 25.
thank you
boatster
boatster101 is offline   Reply With Quote
Old 01-03-2005, 09:21 PM   #21
In MCP hi hi . I am using the pre drilled hole on the roll bar . Do u have any problem doing the throttle linkage mod
Old 01-03-2005, 10:10 PM   #22
Bro, what is MCP? I still dun have my Savage yet. Winnie says about 1 - 2 days time
Anyway, in the meantime, I am getting all the other stuff for it so that everything will be ready when it comes. I bought a new hump pack, CA glue, 10000WT diff oil and a new fuel filter. Maybe later I might be going down to Tai Sing to get the spider gear set for the diff mod and 30000WT diff oil for the front diff. I haven't found the stuff for the throttle mod yet. I think Winnie should have.
Some pics that might help with the throttle linkage mod.
Meet up lah once we got both our Savages settled then we can discuss what to do next. Hopefuly I can get mine ready by Sat afternoon.
Old 01-03-2005, 11:06 PM   #23
Emaxx cannot make it?! ok...once i get my truck, i'll race with u....let's not compare run time coz electric cars sure lose out for sure... :L
But performance wise, i think if it's properly configured in terms of motor selection, battery voltage, amp draw, etc...Electric can be good also....hassle free...
once u go into a good electric setup, u'll want to stick with it coz u just carry two box to the field/track....the car, your TX box and spare batts...
no messy nitro, no fuel bottle, no starter kit.
Disadvantage about batt is that u either gotta have lots of batt packs or have a good field charger...otherwise 2 or 3 packs and u have to call it a day...
Nitro u just pump, and go, pump and go until your tank runs out.
4Wheeler is offline   Reply With Quote
Old 01-03-2005, 11:11 PM   #24
The Emaxx is a good MT to start with too. A dual brushless setup would outrun any nitro MT.
Old 01-03-2005, 11:39 PM   #25
not necessary...Brushless motors might have less torque as compared to brushed motors...so there's no way electric MT can fight for power with a nitro. But top end speed, i think they can be compared.
Only thing about electric is that your neighbour won't be calling in the police for noise when u run your trucks at the carparks. :L
Old 01-04-2005, 12:56 AM   #26
multi story carpark. by the way i stay at northern part of singapore maybe we can meet up when u completed your new toy . u stay in the north also
Old 01-04-2005, 06:23 PM   #27
WC
WC's Avatar
Trader Rating: 17 (100%+)
From my experience, BL usually got *more* torque than brushed.
And also the torque is 100% available from zero rpm, unlike nitro engine that has to rev up before you got torque.
BLs got enough torque to twist the centres out of touringcar wheels and also twist dogbones.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 01-04-2005, 06:24 PM   #28
WC
WC's Avatar
Default SS Savage DISCONTINUED??!! 8(
Tower Hobbies link
Tower Hobbies has the SS as "discontinued", no more stock to sell.
www.PandaGFX.com
www.MelbRC.org
Old 01-04-2005, 06:30 PM   #29
WC
WC's Avatar
Originally posted by firegarden777
If I'm not mistaken, the updated differential should be indicated on the box. Anyway, I'll still be getting the extra spider gears just in case I blow my differentials.
Only the RTR Savage has the new 4-spider diffs, not SS kits.
There is a sticker on the box if so.
Last batch of SSs had no sticker on the box = no new diffs.
Winnie had spare diff gears anyway for you to upgrade.
I bought a spare whole diff (HPI retail package), that too is only 2-gear.
I have been running 4-spider since day 1 and have already
blown the rear diff. The gears chewed thru the plastic cup,
then chewed themselves up. Has only drank < 3L fuel all up.
I think its too many wheelies on grass...
www.PandaGFX.com
www.MelbRC.org
Old 01-04-2005, 06:36 PM   #30
Default Re: SS Savage DISCONTINUED??!! 8(
Originally posted by WC
Tower Hobbies link
It shouldn't be a problem as long as there are still hop-ups and spares. Anyway there should be a new Savage SS with a .28 engine coming up soon. Bummer, since I just getting my Savage.
WC, were you using the stock diff grease or diff oil on your diffs???
Forum Jump
Sembang sembang kedai kopi rizal_eg9 Malaysian R/C Racers 1076 05-21-2009 07:07 AM
>>> TONS OF STUFF: SAVAGE, RC10GT, Tamiya Mini Cooper, E-Savage, MGT, Spektrum <<<<<< mach51 R/C Items: For Sale/Trade 18 09-28-2007 10:14 AM
hpi savage purple integy resivior shocks and savage tires badass_savage21 R/C Items: For Sale/Trade 2 05-15-2006 11:54 AM
Savage 25 And Traxxas Stampede And Savage 21 For Sell Richman R/C Items: For Sale/Trade 0 11-15-2004 10:26 AM
Team Kopi AO Singapore R/C Racers 1172 05-01-2003 06:22 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
