Go Back   R/C Tech Forums > International Forums > Singapore R/C Racers
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-13-2005, 05:54 AM   #151
civiclized esi's Avatar
Bought the same set at winnie and the package does'nt come wif a ball link also. For stripped screw what u have to do is to cut a stright groove deep enough for a flat head screw driver. Must be deep enough so that u can unscrew the screw it as if it is a normal flat head screw. Hope it helps.
civiclized esi is offline   Reply With Quote
Old 01-13-2005, 07:23 AM   #152
Guys care to share what equipments u all use on your savages
1)Steering servo
2)Throttle servo
3)Engine
4)Receiver
5)Others
Old 01-13-2005, 08:47 AM   #153
firegarden777's Avatar
1)Steering servo
2)Throttle servo
3)Engine
4)Receiver
5)Others
My equipment:
1) Hitec 645MG
2) Futaba 3003
3) Nitrostar S25
4) Futaba 3CH PCM receiver
5) Futaba 3PK, HPI Q6 wheels, HPI diff oil and Trinity shock oil.
firegarden777 is offline   Reply With Quote
Old 01-13-2005, 10:28 AM   #154
Send a message via Yahoo to Buggyboy
Default New Savage owner
Hi guys, got this SS kit only 2 mths ago and finished it by end Nov but just only ran in 2 tanks so far...wanna join fellow Savage owners bashing in Sembwang...lemme know when you guys have Savage grp run? Thanks!
Buggyboy is offline   Reply With Quote
Old 01-13-2005, 10:31 AM   #155
leave ur contact in a pm to me. i will arrange to call u guys.
Guyver is offline   Reply With Quote
Old 01-13-2005, 10:33 AM   #156
Originally posted by firegarden777
I was thinking of that too. But can a normal luggage bag hold the Savage and accs. Or would it be too big, then we all look like going to Changi Airport
i tried using a VERTIKAL duffel bag.. i think it is the 40litres capacity type .. barely can fit in the truck.. but still can
Old 01-13-2005, 10:40 AM   #157
Default Vertical luggage bag
The ones at sale for normal luggage looks quite ok, especially the vertical ones...sometimes u can get two sizes for $39
Old 01-13-2005, 10:42 AM   #158
Default Re: Vertical luggage bag
yeah yeah . btw .. did u read up on the post i make on the required items for savage to perform well ??
Old 01-13-2005, 10:44 AM   #159
Default Savage to perform well
Yeah I did read those, very insightful for a new owner cause most of my parts still very stock as running in still not over yet so dare not lean out engine yet...think you understand...must get infra red temp gauge though...
Old 01-13-2005, 10:46 AM   #160
Default Re: Savage to perform well
yup.. get the temp probe at winnies for $50 small and handy.. cute cute somemore .. btw . the shop is in orchard plaza.
Old 01-13-2005, 03:54 PM   #161
Hey Buggyboy welcome to our little corner. Like Guyver said it IS a must to get a temp probe IMHO. However having said that, you still can lean out your engine but not to full performance. You can give it "water treatment" heheh.
By using a drop of water on the cooling head, you can ensure that the temps are ok. After running the truck for a while, put a drop of water on the cooling head and check. If the water just stays there and slowly evaporates then your engine is cool. If it SLOWLY bubbles then evaporates then that's about just right. But if it BOILS OFF immediately, the temp is TOO HIGH. Remember to check often.
You can start to lean out the engine a bit by using this method but as I said in an earlier post, anything more would be dealing with death.
Anyway, I got out my stripped screw yesterday *phew*
Used a vice grip. What is the ideal amount of locktite to use on a screw?
Old 01-13-2005, 04:01 PM   #162
ah, just a reminder for those going bashing together, remember to organise your freq list...
u know what will happen if not right?
ken39 is offline   Reply With Quote
Old 01-13-2005, 05:29 PM   #163
Yes especially for me. I only got one PCM crystal
Old 01-13-2005, 06:22 PM   #164
Old 01-13-2005, 07:02 PM   #165
zonerx's Avatar
Send a message via Yahoo to zonerx
1)Steering servo
2)Throttle servo
3)Engine
4)Receiver
5)Others
mine
1)Hitec 645MG
2)can't remember, should be standard sanwa servo
3)Hyper 8 port w/ps
4)Sanwa MX3 Rx & Tx
5)Maxx mulcher tires with off set wheels, reverse gear, solid alum upper arms, 3mm thick vertical chassis plate, titanium shafts & links, titanium drive gear(or other gear, can't remember), servo saver mod, silver shock springs & alum shock towers.
zonerx is offline   Reply With Quote
Forum Jump
Sembang sembang kedai kopi rizal_eg9 Malaysian R/C Racers 1076 05-21-2009 07:07 AM
>>> TONS OF STUFF: SAVAGE, RC10GT, Tamiya Mini Cooper, E-Savage, MGT, Spektrum <<<<<< mach51 R/C Items: For Sale/Trade 18 09-28-2007 10:14 AM
hpi savage purple integy resivior shocks and savage tires badass_savage21 R/C Items: For Sale/Trade 2 05-15-2006 11:54 AM
Savage 25 And Traxxas Stampede And Savage 21 For Sell Richman R/C Items: For Sale/Trade 0 11-15-2004 10:26 AM
Team Kopi AO Singapore R/C Racers 1172 05-01-2003 06:22 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
