Autodrift enRoute-JXR003 CS ready Chassis
Autodrift enRoute-JXR003 CS-Chassis
1/10 drift chassis
Aluminum parts: black anodize
Chassis: Titanium colored carbon composition chassis
Main characteristics:
6061-T6 is used for the main aluminum parts.
Standard specification 1:1.6 drive ratio (front and rear)
suitable for straight and saddle pack batteries
large diameter front one way.
Set contents:
• Complete set of upper and lower chassis
• Front and back shock tower
• Aluminum motor mount
• Front and back aluminum bulk head
• Complete set of aluminum steering set for large rudder angle
• Front and back suspension block (with suspension pin)
• 37T front one-way pulley
• 16T/21T aluminum center pulley
• 30T solid axle aluminum rear pulley
• Rear aluminum belt tensioner
• Large diameter front one way (with cup)
• Rear aluminum rigid hub
• Complete set of front bumper
• Battery holder for straight battery
• Saddle pack battery friendly (without battery holder)
• Full Titanium screw
JXR003 Manual
Please feel free to share your setup and information here!
Thank you.
Autodrift enRoute-JXR003 CS-Chassis Option Parts:-
JXR121 Alu Suspension Block #0 Degree
JXR256 Alu Suspension Block #1 Degree
JXR120 Alu Suspension Block #2 Degree
JXR122 Alu Suspension Block #3 Degree (Included)
JXR207 Gear Differential 37T/38T
JXR306 Alu Steering Knuckle 0 Degree
JXR253 Alu C-hub 8 Degree
JXR303 Alu Rear Upright 0 Degree
JXR267 Alu Front Upper Brace
JXR297 Alu Steering Bridge T2
JXR244 Carbon Front Bumper
JXR260 High RPM Motor Cooling Fan
Installation Guide
JXR218 Wide Angle Universal Joint 45mm (Included)
JXR208 - 20mm Titanium Carbon Linkage Rod
JXR209 - 25mm Titanium Carbon Linkage Rod
JXR210 - 30mm Titanium Carbon Linkage Rod
JXR211 - 35mm Titanium Carbon Linkage Rod
JXR212 - 40mm Titanium Carbon Linkage Rod
JXR299 - 45mm Titanium Carbon Linkage Rod (Included)
JXR213 - 50mm Titanium Carbon Linkage Rod
JXR236 - 54mm Titanium Carbon Linkage Rod
JXR214 - 65mm Titanium Carbon Linkage Rod
JXR118 Front One-Way Unit (Included)
JXR226 Alu Front One-Way Pulley 37T
JXR138 Alu Rear Pulley 30T (Included)
JXR311 Alu Spring Retainer
JXR315 Alu Servo Stays (Included)
We will update here when more Option/Premium parts available!!!
Installation Guide
Autodrift enRoute Premium Items
ENR012 enRoute Patch
EXL008 enRoute Key Chain
EAH007 enRoute Neck Strap
Hi there Mr Sia,
Recently my JXR suddenly became rear wheel drive.. Front wheels not moving as per normal. Is there something wrong/damaged??? Sorry, very newbie here lah..
Can you bring your car to us to check? We will be open on tomorrow as well as National Day from 12:30pm to 5:30pm.
Thank you.
Hakimo Namoto
Surface- tile surface
Front
Camber: -3 deg
Toe: stock -2 deg out overall
Pro-dive: none
Caster hubs: jxr 8 deg
Ride height: 5mm
Springs: jxr stock
Bumper weight: 0g
Trailing Steering Block: stock
Sway-Bar: none
Shock Oil: Yokomo #500
Downstop: 2mm
Other:
Rear
Camber: -1 deg
Toe: 3.0 deg in
Pro-squat: none
Ride height: 5mm
Springs: jxr stock
Sway-Bar: none
Shock Oil: losi #900
Downstop: 4mm
Other:
Drive Train
Gearing:
Front One-way stock 37t
Center: stock 16t-21t
Rear: 30T Spool
Spur: stock 92T/48 pitch
Pinion:24T/48 pitch
CS Ratio: stock 1.6
ESC/Motor - enRoute/enRoute 10.5T
Final Gear Ratio (Rear) 92/24 X 30/21 = 5.47
Front
Camber: -3 deg
Pro-dive: none
Ride height: 5mm
Springs: jxr stock
Bumper weight: 0g
Sway-Bar: none
Downstop: 2mm
Other:
Rear
Camber: -1 deg
Toe: 3.0 deg in
Pro-squat: none
Ride height: 5mm
Springs: jxr stock
Sway-Bar: none
Downstop: 4mm
Other:
Drive Train
Gearing:
Rear: 30T Spool
Pinion:24T/48 pitch
CS Ratio: stock 1.6
Large steering angle! More than 50 degree!!!
The picture shown is out of box stock setting without 8 degree C-hub.
Full House of enRoute JXR003 Spare & Option Parts.
Highlights:-
1. Titanium Screws & Turn Buckles
2. Various Sizes of Metal Ball Bearings
3. Steering Arm, Bridge, Post V2
4. Aluminum Clamp Servo Horn (Futaba & JR/KO)
5. Aluminum C-Hub, Steering Knuckles
6. Various Sizes of Front & Rear Drive Belts
7. Wide Angle Front Universal Joint 45mm
8. Wide Angle Front Universal Joint 43mm
9. Various Sizes of Carbon Titanium Linkage
10. Full house of Spare Parts.........
Highlights:-
Surface- tile surface ( woodlands / yishun )
Front
Camber: -4 deg
Pro-dive: none
Ride height: 4.5mm
Springs: jxr stock
Bumper weight: 0g
Sway-Bar: none
Shock Oil: Yokomo #400
Downstop: 2mm
Other:
Rear
Camber: -3 deg
Toe: 3.0 deg in
Pro-squat: none
Ride height: 6mm
Springs: Pro soft 2
Sway-Bar: none
Shock Oil: Yokomo 700
Downstop: 4mm
Other:
Drive Train
Gearing:
Rear: 30T Spool
Pinion:24T/48 pitch
CS Ratio: stock 1.6
ESC/Motor - SP / SP7.5T
Autodrift Pte Ltd
Blk 465, Crawford Lane #01-06, Crawford Court, Singapore 190465.
Mon-Sat: 9:30am~7:30pm, Sun & Public Holiday: 12:30pm~5:30pm (Free Parking)
http://www.autodriftrc.com Email: [email protected] / [email protected]
Contact: 65 6299 4795 / 65 6299 5695 / HP: 65 8155 8112 Facebook: yokomo singapore
Front
Camber: -4 deg
Pro-dive: none
Ride height: 4.5mm
Springs: jxr stock
Bumper weight: 0g
Sway-Bar: none
Downstop: 2mm
Other:
Rear
Camber: -3 deg
Toe: 3.0 deg in
Pro-squat: none
Ride height: 6mm
Springs: Pro soft 2
Sway-Bar: none
Downstop: 4mm
Other:
Drive Train
Gearing:
Rear: 30T Spool
Pinion:24T/48 pitch
CS Ratio: stock 1.6
Autodrift Pte Ltd
JXR setup in YIDM from Hakimo
Make: Enroute
Model: Jxr
Track surface: Smooth carpet (Med grip) @ Tropicana Mall KL
Tire: Maxconcept Ultra Hard
Motor & ESC: ORCA RX2 10.5, Enroute esc 120a
Front
Camber: -7 deg @ -2deg toe
Toe: 0 deg
Ackerman: 0 deg
Pro-dive: 2mm
Caster hubs: Enroute 8 deg
Ride height: 6.5mm
Springs: square mid soft spring
Bumper weight: 30g
Sway-Bar: none
Downstop: none
Other:
- 4th hole from top of shock tower
- Innermost shock hole at arm
Rear
Camber: +2 deg
Toe: 3.0deg
Pro-squat: 0mm
Ride height: 7.0mm
Sway-Bar: none
Downstop: none
Other:
- 2nd hole from bottom at shock tower
Drive Train
Gearing:
Front Oneway
Front: stock 37t
Center: stock 15t/22t
Rear: 30t Spool
Spur: 90T/48p
Pinion: 24T/48p
Ratio: 1.8
Others
Shell: Yokomo AE86
Make: Enroute
Model: Jxr
Front
Toe: 0 deg
Ackerman: 0 deg
Pro-dive: 2mm
Ride height: 6.5mm
Bumper weight: 30g
Sway-Bar: none
Downstop: none
Other:
Rear
Camber: +2 deg
Toe: 3.0deg
Pro-squat: 0mm
Ride height: 7.0mm
Sway-Bar: none
Downstop: none
Other:
Drive Train
Gearing:
Front Oneway
Front: stock 37t
Rear: 30t Spool
Spur: 90T/48p
Pinion: 24T/48p
Ratio: 1.8
Others
Shell: Yokomo AE86
