Whopping 160Amp ORCA VRITRA VTC PRO-Spec is one of the only few in the market that will support both STOCK and MODIFIED racing in the very highest level of racing in one powerful ESC! With the programming of the ESC done through the included LCD programmer.
Support Sanwa FHSS Digital High Response System(R), Sanwa FHSS Digital High Response System(R) is the fastest response trasmitter in the world. Matched to the ORCA VRITRA TC PRO Spec. and New ROAR Stock Spec LED indication system, allows for easy tech inspection when running the software to ROAR specs for the upcoming stock class(0 timing)
SPECIFICATIONS:
- Support both Stock and Modifed
- Multiple Adjustable Parameters : 12 Parameters
- Adjustable Drive Frequencies : Yes
- Motor Type : 540 Size Sensored/Sensorless
- Motor Limit : Over 2.5T
- Voltage Input : 4.8V - 9.9V DC, 4-6 Cell NiCD/NiMH, 2 Cell LiPo/1-3 Cell LiFe
- Dimensions : 42(L) x 33.5(W) x 36(H) mm, with fan attached
- Weight : 66g(Without wires)
ORCA VRITRA VC4 PRO SPEC ESC with the programming of the ESC done through the included LCD programmer, there will always be an optimum setting for the motor you decide to use. Provide you with the smoothest and linear driving feel when you pull the trigger. Also support Sanwa FHSS Digital High Response System(R), and new ROAR Stock Spec LED indication system(0 timing)
SPECIFICATIONS:
- Motor Limited : Over 5.5T
- Motor Type : 540 Size Sensored / Sensorless
- Voltage Input : 4.8V-9.9V DC, 4-6 cells NiMH / NiCD, 2 cells LiPo / 2-3 cells LiFe
- Dimensions : 42(L) x 33.5(W) x 33.5(H)mm with Fan Attached
- Weight : 65g (With out Wires)
ORCA release our new Power Boost for the ESC, which transfers unutilized current back into the ESC for more effective use of current throughout the whole system, improving run time, providing you with the best available voltage and consistency throughout your run.
FEATURES
- Suitable use in 7.4V(2cell) LiPo
- Over 3.5Turns brushless motor
- Only use in sensored motors
- Increase ESC efficiency
- Improve run time
- Dimensions 24 x 11 x 15mm
- Weight 16g
ORCA release our most powerful battery to date, the new INFINITE 5500mAh 7.4V 50C competitions race pack that is ideal for racing needs of the hightest level. it will give you power what you want. Featuring highest overall voltage, reliable power output and longer run time. Durable carbon fibre design etching hard case to protect your LiPo during use.
SPECIFICATIONS
- Capacity 5500mAh
- Voltage 7.4V
- Discharge Rate 50C
- Weight 296g
- Dimensions 137(L) x 47(W) x 25(H) mm
- 4mm gold connector
- 2mm gold connector for balance charge
- Carbon fibre design etching hard case
Orca clinched 4th by Azri Amri at Futaba Cup 2011 (January 9th, 2011)
It was reported by ORCA that Azri Amri of Team Orca had taken A-Main 4th in the Open Brushless Class at the Futaba Cup 2011. Powering his Kyosho TF6 using the Orca Vritra TC Pro-Spec ESC and Orca Infinite 6000 60C LiPos, Azri Amri powered his way into the A-Main. The Open Brushless Class was won by Atsushi Hara, followed by Jilles Groskamp, Surikarn and Azri Amri. Orca powered Azri Amri at 13.8s fastest lap was one of the only 5 drivers who made laptimes below 14 seconds. Congratulations to Azri Amri and Team Orca for the great results, and we look forward to perform better at the upcoming TITC!
In photo, Azri Amri (right) with fellow countrymen Halim Hafni(left)
www.quantumracing-rc.com
www.quantumracing-rc.blogspot.com
Find us on Facebook: www.facebook.com/quantumracinghobby and like us
enquiries@quantumracing-rc.com
Orca Podium Modified Class at Racecraft Infinity On-Road Series 4 (January 9, 2011)
The Racecraft Infinity On-Road Challenge Series 4 was held on January 9th in Singapore. This is the final series and the points from this race is a compulsory for the series accumulated points. Orca completed the final podium spot by P.Y.Tang in his Orca powered Xray T3'11. Despite disruption by on and off rain, the race was able to complete after a long day. In the Modified Class, qualifying was a tight fight between the top 4 all clocking at 21 laps. Nicholas Lee took the TQ spot followed by Alvin Koh. E.C.Wee shaved 7 seconds from his previous race to qualify 3rd ahead of P.Y.Tang in 4th. Nicholas Lee took the win in Final A1, while P.Y.Tang took the win in Final A2. It was down to the Final A3 that the champion was crowned as the race was wide open for Nicholas Lee, Alvin Koh and P.Y.Tang. A cleaner start in Final A3 saw all drivers stuck at the original position where it started off, except P.Y.Tang able to pass E.C.Wee for the 3rd spot. E.C.Wee had some mishap during the Final A2 dropping him down the table and out of contention for the podium, but finished in a respectable 4th.
Roy JJ of Singapore to run H-Energy LiFe Receiver Pack for 2011 season
Roy JJ of Singapore will run the new H-Energy LiFe 1400Mah Hump Pack Type 2 in his Serpent 811 for the 2011 season supported by Team H-Energy and Team Quantum. Roy JJ has been testing and using the H-Energy receiver pack since 2010 and will continue to powered his Serpent by H-Energy. The H-Energy LiFe 1400Mah Hump Pack Type 2 is slightly different in size, compared to the Type 1, is designed for a perfect fit in the Serpent 811 battery box. Roy JJ has won numerous regional 1/8 buggy races including the recent win at the Thunder Tiger Cup in Malaysia. We look forward to support Roy JJ in developing the H-Energy product in the region.
H-Energy New LiFe Receiver Hump Pack Type 2 for 1/8 Serpent 811 Buggy @ Quantum!
Specially designed for use in the 1/8th Serpent 811 Off-Road Buggy, it fits perfectly in the receiver pack box. High performance and high reliability LiFe technology eliminates the use of LiPo voltage regulator. Also suitable for other similar applications.
Type: LiFe Receiver Pack Hump Type 2 For 1/8th Gas Buggy or equivalent
Capacity: 1400Mah
Nominal Voltage: 6.6V
Discharge Rate: 5c
Size TxWxL: Approximately 29*30*56mm
H-Energy NiMh 6.0V Receiver Pack, New Arrival @ Quantum!
Standard NiMh receiver pack, H-Energy NiMh 1500Mah 6.0V Receiver Stick Pack for use in Nitro racing. Used by many racers around the world who have not converted to LiPo or LiFe technology, this receiver pack gives the racer a peace of mind.
Type: NiMh Receiver Pack Stick Type
Cell: 5-cells
Capacity: 1500Mah
Nominal Voltage: 6.0V
Size TxWxL: Approximately 17*28*83.5mm
New H-Energy LiFe 1400Mah 6.6V Receiver Pack @ Quantum!
H-Energy introduced its new range of LiFe receiver pack stick type. Featuring a capacity of 1400Mah enough for a 1-hour race in nitro racing. Low nominal voltage of 6.6V eliminates the use of LiPo voltage regulator and also a much safer battery type.
Also suitable for Futaba 4PK, Futaba 4PKS and any 6.0V operating voltage transmitter.
Huge R/C Product, the new brand from 2002 ISTC World Champion Surikarn Chaidajsuriya, will be in stock soon @ Quantum!
You can now get high quality ceramic bearing sets for both the Xray NT1 (19 pieces) and T3 (14 pieces). These bearings are lighter and harder than the standard steel versions and have minimal friction for a smoother and freer drive train. More ceramic bearing sets will be available soon. Other product range from Huge R/C includes LiPo batteries, CA Glue, Spring Holder, Thrust Bearings, Ceramic Diff Balls and many more to come.
LiPo Chassis Conversion Kit for Tamiya F104 and HPI Racing F10!
Orca Dominates the 13.5T and 17.5T Class at the 2011 Canadian On-Road Nationals!
The 2011 Canadian On-Road Nationals Indoor Carpet RC race showcase the best RC racers in Canada. The 2011 event was held in the centre court of the Seaway Mall, Welland, ON from Jan 21-23, 2011.
Team Orca USA brought us the good news that Martin Crisp, Andrew Hardman and Keith Yu dominated the event with the TQ honor and 1st, 2nd and 3rd podium for the 13.5T and 17.5T Open Rubber Class.
Congratulations!
13.5T Open Rubber
1st Martin Crisp (TQ)
2nd Andrew Hardman
3rd Keith Yu
17.5T Open Rubber
2nd Keith Yu
3rd Andrew Hardman
