1/8 GP On Road Discussion Thread
This will be a new tread for 1/8 on road. Newbies ask any question or need advise. Im sure the experience drivers are more then wiling to help.
Question: How do we select a bodyshell? Based on look i go for the P909
But there are like 2 seat 1 missing driver cover some Zytec thing.
On a 1/8 does the technicality of a track suggest a particular bodyshell or is a suit this chassis kind of thing?? A growing number are buying the 909 for the looks and style.
Enlighten please
Enlighten please
Will be testing the new R11 from Titan this weekend.
picture got from Redrc.net
Enlighten please
Enlighten please
The P909 is the flavor of the month so i heard, perhaps its has good downforce and still steers good. BUT, IFMAR might be banning it for 2011 Worlds...
Which starer box for v8?
Engine Break-in
Hi,
Have been reading up on enging break-in... from what I have read, there are basically 2 Schools...
1) Let engine idle on box for 1st tank. For the next 5 tanks, run at rich setting. Subsequent tanks, gradually lean high speed.
2) Run engine at slightly rich setting, stopping every 2-3 mins. Let it cool, then repeat again till about 15 mins. Then increase to about 3-4 mins for about the next 15 mins. Start to lean high speed thereafter.
Was wondering what you guys are doing to break-in your engines.
I guess... if I understand it correctly... what we basically want is to heat cycle the engine parts...
Please do share... thanking all in advance...
Sam
Sam
for me start engine run and run and run and run ..
then lean lean and go forth and run like siao then throw away and buy new one
Sammies, there is alot of threads in the onroad forum on how to break in a engine, there is no perfect or 100% correct way. Ultimately yes, you would wan to heat cycle the engine.
Words of wisdom from our very own 1/8 guru X4....
I'm not a guru at all!
Sammies, if you really wan to learn or need help running in a engine, go down to PA track on wkends and look for a "bear". Friendly, helpful and expert at tuning engines.
Yup... want to learn... so far... the 2 engines I have were broken in by a friend... but want to learn so that I can do it on my own.
Going to rebuild my OS soon... so thought it would be a good opportunity for me to get 1st hand experience
Will look out for 'bear' at PA. I'm usually down on the weekends as well.
Hope to see you guys around... probably have passed each other at PA... I will be sure to say hi next time round
R11 is it ready for sale???
i think ARC do have 2 or 3 left... Check Pason Out
