Go Back   R/C Tech Forums > International Forums > Singapore R/C Racers
Old 06-26-2012, 08:02 AM   #166
Nov
Nov's Avatar
For those who asked. Could be better with more rpm and slightly less rear side-grip.
Make: Yokomo
Model: DRB
Track surface: Rough Pebbles @ CCK Lot One
Tire: Autodrift Pro-grip
Motor & ESC: Team Powers 11.5 (12.3mm), Hobbywing 120A V2.1
Front
Camber: -4 deg @ 0deg toe
Toe: 2 deg out
Ackerman: +2 deg (Overdose steering set)
Pro-dive: 0mm
Caster hubs: Overdose 6-8 (Should be 6 deg)
Ride height: 5mm
Springs: Mikuni Yellow
Bumper weight:
Trailing Steering Block: Overdose 6-8 set
Sway-Bar: none
Shock Oil: Yokomo #700
Downstop: -
Droop: 5mm
Other:
- Topmost hole of shock tower
- Outermost shock hole at arm
Rear
Camber: -2 deg
Toe: 2.0deg + 0.5hub
Anti-squat: 1mm
Ride height: 5.5mm
Springs: Yokomo DMax HSS Black
Sway-Bar: None
Shock Oil: Yokomo #500
Downstop: -
Droop: 5mm
Other:
- 3rd hole from top of shock tower
Drive Train
Gearing:
Front Oneway/Rear FCD1.3 Spool
Front: stock 40t
Center: 12t
Rear: Yokomo FCD1.3 (31T)
Center: 17t
Spur: 116T/64p
Pinion: 38T/64p
Ratio: 1.827
Others
Shell: Yokomo S15
Rim Offset: +7mm front, +9mm rear
Battery: Intellect LiFePO4 3600mAh
- Nov -
An average happy driver!!
Miku RB3 ODC Ver3
Nov is offline   Reply With Quote
Old 09-18-2012, 08:39 AM   #167
7colours's Avatar
Make: Yokomo Drift Package
Model: DIB Red
Date: 16/09/2012
Track surface: Tiles(autodrift shop)
Tire: AutoDrift ProGrip
Motor & ESC: SP 11.5T,HW 120A w/out turbo
Front
Camber: -5deg
Toe out: 2deg
Kick up: none
Caster hubs: -10degs
Ride height: 5.5mm
Droop: 6mm
Downstop: 2mm
Springs: Yokomo black series(pink)
Bumper weight: none
Trailing Steering Block: stock
Sway-Bar: none
Shock Oil: Yokomo 300W,3 holes pistons
Shock postion:
Upper}nearest to wheel
Lower}nearest to bulkhead
Other:
Rear
Camber: -2deg
Toe: -3deg
Anti squad: 1mm
Ride height: 6mm
Droop: 2mm
Springs: Yokomo black series(black)
Downstop: 6mm
Sway-Bar: 1.2
Shock Oil: Yokomo 150W,3 hole pistons*
Shock postion:
Upper}2nd hole nearest to bulkhead
Lower} nearest to wheel
Other:
Drive Train
Gearing:
Front 1-way / Rear Spool
CS Ratio: 1.82%
Spur: 96T/48 pitch
Pinion: 23T/48 pitch
Internal drive ratio: 4.17
Final drive Ratio: 6.12
Others:
6mm offsets rims for front with 3mm wheel hex.
6mm offsets rims for rear with
6mm wheel hex.
Team Drift or Die,Singapore(D.O.D)
We either drift or play dirt.............
Supported by Monster Energy drink SG,Drift Instinct,Drift Society.
Sponsored by Drift Culture,Maxpower Lipo Battery.
7colours is offline   Reply With Quote
Old 09-20-2012, 04:12 AM   #168
RTECH's Avatar
Bro, wat is the rear width of your DIB measure from the outerface of the wheel to wheel? Coz different car different arm length.
做人难, 做好人,更难。
Or tar-R 三一。
http://sgcrawlers.forumotion.com/forum
RTECH is offline   Reply With Quote
Old 09-23-2012, 08:52 AM   #169
7colours's Avatar
This r d setup i've done tdy @ autodrift DM
There's still minor adjustment to do in order to make d car handles better on lower CS ratio
Model: DIB Red
Date: 23/09/2012
Front
Camber: -3deg
Toe out: 2deg
Kick up: 2.5mm
Ride height: 4.5mm
Droop: 7.5mm
Downstop: 4.5mm
Springs: Yokomo black series(black,s/soft)
Bumper weight: none
Sway-Bar: none
Shock: Yokomo 300W,3 holes pistons,single 'O'-ring
Shock postion:
Upper} 4th hole from bulkhead
Lower} nearest to bulkhead
Other: Center roll + 1mm
Rear
Camber: -1deg
Toe: -3deg
Anti squad: none
Ride height: 6mm
Droop: 9.5mm
Springs: Streetjam medium soft
Downstop: 3mm
Sway-Bar: 1.2
Shock: Yokomo 150W,3 hole pistons,single 'O'-ring
Shock postion:
Upper} 3rd hole nearest to bulkhead
Other:
Drive Train
Gearing:
CS Ratio: 1.53%
Spur: 96T/48 pitch
Final drive Ratio: 7.23
Others:
5mm wheel hex.
There's still more setups to try.
Old 10-06-2012, 08:59 AM   #170
7colours's Avatar
Hi DIB owners.......this r some setups i've done on carpet.
Model: DIB Red
Date: 06/10/2012
Track surface: Carpet(StRevo shop)
Tire: DS F0
Front
Camber: 0deg
Toe out: 2deg
Kick up: none
Ride height: 5mm
Droop: 4mm
Downstop: 4mm
Bumper weight: none
Sway-Bar: none
Shock postion:
Upper} 5th hole from bulkhead
Other:
Rear
Camber: 0deg
Toe: -2deg
Anti squad: none
Ride height: 5.5mm
Droop: 6mm
Downstop: 2mm
Sway-Bar: none
Shock postion:
Other: roll center +2mm
Drive Train
Gearing:
CS Ratio: 1.48%
Spur: 96T/48 pitch
Final drive Ratio: 7.51
Others:
5mm wheel hex.
Old 10-10-2012, 09:59 AM   #171
Nov
Nov's Avatar
Been trying out CS1.5 for a week or so on my DRB and after some discussion with Didee & Hakimo, I find this to be a pretty good setup with considerable CS angle. The car is a bit tail happy, but increasing rear toe helps stabilizing it. Feel free to ask me for more details.
Make: Yokomo
Model: DRB
Track surface: Tiles @ Longvale / Redhill DM
Motor & ESC: ORCA RX2 10.5, Hobbywing 120A V2.1
Front
Camber: Front 0 deg @ 0deg toe
Toe: 2 deg out
Ackerman: Parallel
Caster hubs: Yokomo 10deg
Ride height: 5mm
Bumper weight: None
Trailing Steering Block: Yokomo option
Sway-Bar: none
Shock Oil: Yokomo #300
Downstop: 5mm
Droop: 5mm
Other:
- Shock position @ Tower : 3rd from bulkhead
- Shock position @ Arm : Inner of 2pos
- 1mm spacer under FF and FR suspension mounts
- No spacer under camber link ball connectors at bulkhead or C-hub.
Rear
Camber: 0 deg
Toe: 2.0deg - 0.5hub = 1.5deg
Ride height: 5mm
Sway-Bar: None
Shock Oil: Yokomo #150
Downstop: 3mm
Droop: 6mm
Shock position @ Tower : 3rd from top
Other:
- Option Rear upper bulkhead DRB-303RL & 303RR. Camber link at inner hole.
- 3mm spacer under camber link ball connectors at bulkhead, none at hub
Drive Train
Gearing:
Front: stock 40t
Center: 13t
Center: 15t
Spur: 116T/64p
Pinion: 29T/64p
Ratio: 1.488
Others
Shell: Yokomo HKS Altezza
- Nov -
Miku RB3 ODC Ver3
Old 10-11-2012, 04:11 AM   #172
RTECH's Avatar
Its it the high caster angle at zero degree camber make the considerable CS angle at 1.5 ratio?
If using lower caster angle , will the CS angle still considerable?
Thanks.
做人难, 做好人,更难。
Or tar-R 三一。
Old 10-11-2012, 04:40 AM   #173
Nov
Nov's Avatar
Thanks.
IMO there will be less CS angle with lower caster.
It is harder to maintain CS angle with a lower caster angle as there will be more contact area between the tire and ground as compared to a higher caster angle. Therefore with increased grip, the front will pull easily to the direction your front tires are pointing at. But of course the camber factor has to be considered.
Feel free to correct me if I'm wrong, we need to learn from each other to improve...
- Nov -
Miku RB3 ODC Ver3
Old 10-11-2012, 04:50 AM   #174
RTECH's Avatar
Thanks Nov. for sharing the tips.
做人难, 做好人,更难。
Or tar-R 三一。
Old 10-11-2012, 05:54 AM   #175
where in singapore can i get a DRB cause i searching for it?
harastar is offline   Reply With Quote
Old 10-11-2012, 06:54 AM   #176
7colours's Avatar
Autodrift Pte Ltd
Blk 465, Crawford Lane #01-06, Crawford Court, Singapore 190465.
Mon-Sat: 11:00am~8:00pm, Sunday & Public Holiday: 1:00pm~7:00pm (Free Parking)
http://www.autodriftrc.com Email: sales@autodriftrc.com / tssia2007@yahoo.com
Contact: 65 6299 4795 / HP: 65 8155 8112 / https://www.facebook.com/Autodrift
They r our local Yokomo distributor...u can look for d boss,Mr Sia.
Old 10-23-2012, 05:54 PM   #177
Is the DIB Chasis able to fit a battery with the dimensions 138x46x25mm?
FishRFriends is offline   Reply With Quote
Old 10-24-2012, 01:30 AM   #178
yokomo-SIA's Avatar
Send a message via MSN to yokomo-SIA Send a message via Skype™ to yokomo-SIA
Hi,
The best is to use 24.5mm or below.
ProAmp 6000 is nice fit.
Thank you.
Sia
Autodrift Pte Ltd - Contact: 65 6299 4795 / HP: 65 8155 8112
YOKOMO - enRoute - MST -OVERDOSE -MIKUNI -TOPLINE -SPEEDWORKS -PROSTAGE - Acorn Racing
Mon-Sat: 12:30pm~8pm, Sun: 1pm~7:30pm (Free Parking on Sunday & Public Holidays)
http://www.autodriftrc.com Email: sia@autodriftrc.com / tssia2013@outlook.com
yokomo-SIA is offline   Reply With Quote
Old 11-20-2012, 12:09 AM   #179
vivio's Avatar
Default My DRB set up for YIDM2012
Make: Yokomo
Model: DRB
Tire: Max Concept UltraHard
Motor & ESC: YIDM Orca TX 10.5T, Hobbywing V3
Front
Camber: 3.5 deg
Toe: 1 deg out
Ackerman:-
Pro-dive: 0mm
Caster hubs: 12 deg
Ride height: 6.5mm
Springs: Speed Works Pro (Blue)
Bumper weight: None
Trailing Steering Block: -
Sway-Bar: none
Shock Oil: Hpi 10wt
Downstop: 2mm
Droop:-
Other:
Upper} 6th hole from bulkhead
Rear
Camber: 4 deg
Toe: 3.5 deg + 0 deg hub
Ride height: 5.5mm
Springs: Speed Works Pro (soft red)
Sway-Bar: None
Shock Oil: Hpi 10 wt
Downstop: 3mm
Droop: -
Other:
Other: Center roll + 2m
Drive Train
Gearing:
Front Oneway/Rear FCD2.0 Spool
Front: stock 40t
Center: 16t
Rear: Yokomo FCD2.0 (20T)
Center: 14t
Spur: 86 T / 48 P
Pinion: 28 T / 48 P
Ratio: CS 1.75
Others
Shell: Yokomo S14
Rim Offset: Yokomo +4mm front, +8mm rear
Battery: Shorty pack Nano-Tech 4200mah Lipo
Eat! Sleep! Drift!...
Team Atlas
"Not just drifting"
Yokomo . Mugen
vivio is offline   Reply With Quote
Old 12-09-2012, 09:27 AM   #180
yokomo-SIA's Avatar
Make: Yokomo
Model: DRB
Front
Camber: 3.5 deg
Toe: 1 deg out
Ackerman:-
Pro-dive: 0mm
Caster hubs: 12 deg
Ride height: 6.5mm
Bumper weight: None
Sway-Bar: none
Shock Oil: Hpi 10wt
Downstop: 2mm
Droop:-
Other:
Rear
Camber: 4 deg
Ride height: 5.5mm
Sway-Bar: None
Downstop: 3mm
Droop: -
Other:
Drive Train
Gearing:
Front: stock 40t
Center: 16t
Center: 14t
Spur: 86 T / 48 P
Pinion: 28 T / 48 P
Ratio: CS 1.75
Others
Shell: Yokomo S14
Thanks to vivio 's information share at here.
Bintulu Sarawak RC Drift vipb0yz Malaysian R/C Racers 191 09-29-2011 05:46 AM
Countersteer Drift chassis kevinTRF Brunei R/C Racers 49 02-06-2011 04:26 PM
What can i do to make HPI E10 Chassis Better??? Newbie2Probie Brunei R/C Racers 28 11-24-2010 07:24 PM
Tags
drb, hpi, tcd, vdf, yokomo
