Yokomo DRB Drift Chassis
#136
As Charles mentioned, if you throttle more on carpet, you will get more grip...Cos higher rpm makes the tire heat up therefore increasing grip...For overdrive cars, this will cause understeer in most cases as the rear will heat up faster than the front...
Make: Yokomo
Model: DRB
Track surface: Carpet @ Asia AutoSalon 2011
Tire: Autodrift Pro Grip
Motor & ESC: Yokomo Zero 17.5 (0deg timing), Hobbywing 120A V2.1
Front
Camber: 0 deg @ 0deg toe
Toe: -2 deg out overall
Pro-dive: 3mm
Caster hubs: Yokomo 10 deg
Ride height: 5mm
Springs: Yokomo Blue
Bumper weight: 0g
Trailing Steering Block: stock
Sway-Bar: none
Shock Oil: Yokomo #600
Downstop: 5mm
Other:
Rear
Camber: -1 deg
Toe: 4.0 deg in
Pro-squat: 3mm
Ride height: 5.5mm
Springs: Yokomo Black
Sway-Bar: 1.6mm
Downstop: 4mm
Other:
Drive Train
Gearing:
Front Oneway/Rear FCD1.8 Spool
Front: stock 40t
Center: stock 15t
Rear: Yokomo FCD1.8 22T
Center:stock 15t
Spur: 77T/48 pitch
Pinion:26T/48 pitch
Ratio: 1.81[/QUOTE]
Make: Yokomo
Model: DRB
Front
Pro-dive: 3mm
Ride height: 5mm
Bumper weight: 0g
Sway-Bar: none
Downstop: 5mm
Other:
Rear
Camber: -1 deg
Toe: 4.0 deg in
Pro-squat: 3mm
Ride height: 5.5mm
Sway-Bar: 1.6mm
Downstop: 4mm
Other:
Drive Train
Gearing:
Front: stock 40t
Center: stock 15t
Center:stock 15t
Spur: 77T/48 pitch
Pinion:26T/48 pitch
Ratio: 1.81[/QUOTE]
#138
DRB Oneway...
hello... i need help... i haf a major problem wif my oneway which tend to slip... at first it was ok... but now... i cant even do donuts without overspinning... does any of you guys encounter this problem... and if you guys do... how to fix this?
#139
I sprayed the oneway bearings with degreaser, lightly oil them and reinstalled the oneway...Have to do frequent maintenance to make sure the oneway is not dirty...
Hope that helps
#140
Tried this setup at ethen place today, so far are happy with this setup, hope it will help drifter for this weekend competition.
Make: Yokomo
Model: DRB
Track surface: epoxy flooring(smooth) REVO TECH aka Ethen shop
Tire: F1
Motor & ESC: HW 8.5T SP GTV2
Front
Toe: 0
Pro-dive: 2mm
Ride height: 4.5mm
Bumper weight: 50g
Sway-Bar: none
Shock Oil: Yokomo #400
Downstop: 6mm
Other:
Rear
Camber: -2 deg
Toe: 3.5 deg in
Pro-squat: none
Ride height: 4.5mm
Springs: soft
Sway-Bar: 1.2mm
Shock Oil: Yokomo #300
Downstop: 5mm
Other:
Drive Train
Gearing:
Front Oneway/Rear FCD2.0 Spool
Front: stock 40t
Center: stock 16t
Rear: Yokomo FCD2.0 20T
Center:stock 14t
Spur: 82T/48 pitch
Pinion:29T/48 pitch
Ratio: 1.76[/quote]
Make: Yokomo
Model: DRB
Tire: F1
Front
Toe: 0
Pro-dive: 2mm
Ride height: 4.5mm
Bumper weight: 50g
Sway-Bar: none
Downstop: 6mm
Other:
Rear
Camber: -2 deg
Toe: 3.5 deg in
Pro-squat: none
Ride height: 4.5mm
Springs: soft
Sway-Bar: 1.2mm
Downstop: 5mm
Other:
Drive Train
Gearing:
Front: stock 40t
Center: stock 16t
Center:stock 14t
Spur: 82T/48 pitch
Pinion:29T/48 pitch
Ratio: 1.76[/quote]
#141
Settings used during last week's competition...
Make: Yokomo
Model: DRB
Track surface: Epoxy Flooring @ Street Revo
Tire: DS F1 Competition
Motor & ESC: Yokomo Zero 17.5T, Hobbywing 120A V2.1
Front
Camber: -1deg @ 0deg toe
Toe: 0 deg
Pro-dive: 3mm
Ride height: 5mm
Bumper weight: 20g
Sway-Bar: none
Shock Oil: Yokomo #450
Downstop: 5mm
Others:
Rear
Camber: -2.5deg
Toe: 4.0deg
Pro-squat: 3mm
Ride height: 4.5mm
Sway-Bar: 1.6mm
Downstop: 4mm
Others:
Drive Train
Gearing:
Front: stock 40t
Center: stock 15t
Rear: Yokomo FCD1.8
Center: stock 15t
Spur: 106T/64p
Pinion: 34T/64p
Ratio: 1.81
Make: Yokomo
Model: DRB
Front
Toe: 0 deg
Pro-dive: 3mm
Ride height: 5mm
Bumper weight: 20g
Sway-Bar: none
Downstop: 5mm
Others:
Rear
Camber: -2.5deg
Toe: 4.0deg
Pro-squat: 3mm
Ride height: 4.5mm
Sway-Bar: 1.6mm
Downstop: 4mm
Others:
Drive Train
Gearing:
Front: stock 40t
Center: stock 15t
Rear: Yokomo FCD1.8
Center: stock 15t
Spur: 106T/64p
Pinion: 34T/64p
Ratio: 1.81
#142
Make: Yokomo
Model: DRB
Front
Toe: 0 deg
Pro-dive: 3mm
Ride height: 5mm
Bumper weight: 20g
Sway-Bar: none
Downstop: 5mm
Others:
Rear
Camber: -2.5deg
Toe: 4.0deg
Pro-squat: 3mm
Ride height: 4.5mm
Sway-Bar: 1.6mm
Downstop: 4mm
Others:
Drive Train
Gearing:
Front: stock 40t
Center: stock 15t
Rear: Yokomo FCD1.8
Center: stock 15t
Spur: 106T/64p
Pinion: 34T/64p
Ratio: 1.81
Make: Yokomo
Model: DRB
Front
Toe: 0 deg
Pro-dive: 3mm
Ride height: 5mm
Bumper weight: 20g
Sway-Bar: none
Downstop: 5mm
Others:
Rear
Camber: -2.5deg
Toe: 4.0deg
Pro-squat: 3mm
Ride height: 4.5mm
Sway-Bar: 1.6mm
Downstop: 4mm
Others:
Drive Train
Gearing:
Front: stock 40t
Center: stock 15t
Rear: Yokomo FCD1.8
Center: stock 15t
Spur: 106T/64p
Pinion: 34T/64p
Ratio: 1.81
Final Gear Ratio: 106/34 x 22/15 = 4.57
#143
Make: Yokomo
Model: DRB
Tire: F1
Front
Toe: 0
Pro-dive: 2mm
Ride height: 4.5mm
Bumper weight: 50g
Sway-Bar: none
Downstop: 6mm
Other:
Rear
Camber: -2 deg
Toe: 3.5 deg in
Pro-squat: none
Ride height: 4.5mm
Springs: soft
Sway-Bar: 1.2mm
Downstop: 5mm
Other:
Drive Train
Gearing:
Front: stock 40t
Center: stock 16t
Center:stock 14t
Spur: 82T/48 pitch
Pinion:29T/48 pitch
Ratio: 1.76
Make: Yokomo
Model: DRB
Tire: F1
Front
Toe: 0
Pro-dive: 2mm
Ride height: 4.5mm
Bumper weight: 50g
Sway-Bar: none
Downstop: 6mm
Other:
Rear
Camber: -2 deg
Toe: 3.5 deg in
Pro-squat: none
Ride height: 4.5mm
Springs: soft
Sway-Bar: 1.2mm
Downstop: 5mm
Other:
Drive Train
Gearing:
Front: stock 40t
Center: stock 16t
Center:stock 14t
Spur: 82T/48 pitch
Pinion:29T/48 pitch
Ratio: 1.76
Final Gear Ratio : 82/29 x 20/14 = 4.04
#144
Overdose
Hi, does anyone know where I canget the Overdose motor mount? Everywhere i've looked says out of stock.
Failing that if there is anyone who would like to swap an Overdose motor mount set for a new blue Yokomo Hyper motor mount (and brace) let me know
Cheers
Chris
Cheers
Chris
#145
The drb is the best chassis I've ever driven. Superb control. Best for beginner if u want to learn drifting. Bust it's costly.
#146
Boss! Any setup tips to win A-main 1/8 buggy??
[/QUOTE]
Make: Yokomo
Model: DRB
Tire: F1
Front
Toe: 0
Pro-dive: 2mm
Ride height: 4.5mm
Bumper weight: 50g
Sway-Bar: none
Downstop: 6mm
Other:
Rear
Camber: -2 deg
Toe: 3.5 deg in
Pro-squat: none
Ride height: 4.5mm
Springs: soft
Sway-Bar: 1.2mm
Downstop: 5mm
Other:
Drive Train
Gearing:
Front: stock 40t
Center: stock 16t
Center:stock 14t
Spur: 82T/48 pitch
Pinion:29T/48 pitch
Ratio: 1.76
Make: Yokomo
Model: DRB
Tire: F1
Front
Toe: 0
Pro-dive: 2mm
Ride height: 4.5mm
Bumper weight: 50g
Sway-Bar: none
Downstop: 6mm
Other:
Rear
Camber: -2 deg
Toe: 3.5 deg in
Pro-squat: none
Ride height: 4.5mm
Springs: soft
Sway-Bar: 1.2mm
Downstop: 5mm
Other:
Drive Train
Gearing:
Front: stock 40t
Center: stock 16t
Center:stock 14t
Spur: 82T/48 pitch
Pinion:29T/48 pitch
Ratio: 1.76
#147
My setup for today's competition at Streetrevo. Car is stable and easy to drive, but the driver is impatient...Thats why I got 'that' sticker for lucky draw...
Make: Yokomo
Model: DRB
Track surface: Smooth Epoxy Surface @ Street Revo (Low grip)
Tire: DS F2 Competition
Motor & ESC: Yokomo Zero 17.5, Hobbywing 120A V2.1
Front
Camber: -2 deg @ 0deg toe
Toe: 0 deg
Pro-dive: 2mm
Ride height: 5.5mm
Bumper weight: 20g
Sway-Bar: none
Downstop: 5.5~6.0mm
Other:
- 4th hole from top of shock tower
- Innermost shock hole at arm
- Roll Center raised 1mm
Rear
Camber: -2 deg
Toe: 4.0deg
Pro-squat: 3mm
Ride height: 4.5mm
Sway-Bar: 1.6mm
Downstop: 5.0~5.5mm
Other:
- 3rd hole from bottom at shock tower
Drive Train
Gearing:
Front: stock 40t
Center: stock 15t
Rear: Yokomo FCD1.8
Center: stock 15t
Spur: 106T/64p
Pinion: 36T/64p
Ratio: 1.81
Others
Shell: HPI Honda Odyssey 200mm
Rim Offset: +7mm front, +9mm rear
Battery: Intellect LiFePO4 3600mAh
Make: Yokomo
Model: DRB
Front
Toe: 0 deg
Pro-dive: 2mm
Ride height: 5.5mm
Bumper weight: 20g
Sway-Bar: none
Downstop: 5.5~6.0mm
Other:
Rear
Camber: -2 deg
Toe: 4.0deg
Pro-squat: 3mm
Ride height: 4.5mm
Sway-Bar: 1.6mm
Downstop: 5.0~5.5mm
Other:
Drive Train
Gearing:
Front: stock 40t
Center: stock 15t
Rear: Yokomo FCD1.8
Center: stock 15t
Spur: 106T/64p
Pinion: 36T/64p
Ratio: 1.81
Others
#148
Song song to jurong setup at sengkang
Make: Yokomo
Model: DRB
Track surface:tiles blk 186 sengkang
Tire: Autodrift pro grip
Front
Toe: 0
Pro-dive: 1.5mm
Ride height: 5mm
Springs: Yokomo green
Bumper weight: 50g
Sway-Bar: none
Downstop: 6mm
Other:
Rear
Camber: 1 deg
Toe: 3.5 deg in
Pro-squat: none
Ride height: 5mm
Springs: soft
Sway-Bar: 1.2mm
Downstop: 5mm
Other:
Drive Train
Gearing:
Front: stock 40t
Center: stock 16t
Center:stock 14t
Spur: 82T/48 pitch
Pinion:25T/48 pitch
Ratio: 1.76
Make: Yokomo
Model: DRB
Front
Toe: 0
Pro-dive: 1.5mm
Ride height: 5mm
Bumper weight: 50g
Sway-Bar: none
Downstop: 6mm
Other:
Rear
Camber: 1 deg
Toe: 3.5 deg in
Pro-squat: none
Ride height: 5mm
Springs: soft
Sway-Bar: 1.2mm
Downstop: 5mm
Other:
Drive Train
Gearing:
Front: stock 40t
Center: stock 16t
Center:stock 14t
Spur: 82T/48 pitch
Pinion:25T/48 pitch
Ratio: 1.76
#150
I think you would have better luck finding the motor mount online...Didn't see this being sold in local retail shops, and I think I'm the only one using the Overdose mount in Singapore cos I haven't seen anyone else using it yet...
Do note that the Hyper SSG Upper bridge is not compatible with this mount cos the new upper bridge is thicker and taller than the old one...
