Hi guys, anyone hear or test on ZTW?
#17
hi you know what is the difference esc 120 and the esc 60? i saw the esc 60 come with programming card. any size difference? anyone got a picture?
#19
Thanks.
#20
#21
hi i got a use ta05 and bought ztw esc 60a i run the 6.5 motor the car is very punchy when press throttle. how to make the car less powerful?
#23
#25
A more detail explanation would be using your programcard ...adjust menu 3(motor timing) to number 1 and menu 4(initial accelaration) to number 1 as well.. remember to off the esc before you disconnect the programcard else the setting wont be save. Like wat thirtycents said the esc software was set with plenty of power suitable for stock racing but can be adjusted to a user's need.
#26
ok..done thank q. programming card setting change to 1 now the car more easier to drive tomorrow i will try setting 2
#28
Hi Sinrc85,
How's the ZTW ESC going? If there are anymore problems, just post it here, we will attend to you promptly.
Thanks.
Thanks.
#29
Hi,
Can anyone try helping me...??
My ZTW 35A 9T is running alittle hot (not able to touch)... fit on a motor-fan and it juz bring the temperature down a little...
