MO5 Pro Thread
#32
Any recommendation for what servo to be used on m05?
#33
That depends on what u plan on bashing or racing. If u r bashing, almost any regular servos also can use cos it does not require alot of torque. If u r planning on racing, then maybe u might want to consider better servos like Sanwa VR or Futaba 9551 or equivalent. Reason is that u want that better precision and speed in steering. My two cents worth.
#34
$190? where to buy?
#40
however, in the Philippines, the ordinary MO5 run around PhP3,695 (about SGD108) - http://www.rctech.net/forum/6553279-post12690.html - only (comes with a mini Rover body, silver can motor and an esc)... so the savings will probably be very small if i convert an MO3 to MO5
#41
theoretically speaking (if you can get good prices of the MO5 plastic parts), it might be cheaper to convert the MO3R... and you probably end-up with a good looking MO5 which is very competitive with the MO5 PRO
Hi guys, done my convertion already....
Just in case any bro want to spent less by converting...
Parts that needed to convert:
- Tamiya M05 A Part
- Tamiya M05 B Part
- Tamiya M05 c Part
- Tamiya M05 D Part
- Tamiya M05 F Part
- 3 Racing steering Linkage 95mm
- Tamiya M05 Adjustable Upper Arm Set
Price pls check with the Local hobbyshop if you want to convert.
#42
- Tamiya M05 A Part
- Tamiya M05 B Part
- Tamiya M05 c Part
- Tamiya M05 D Part
- Tamiya M05 F Part
- BA11 x2 Step Screw (where can i get huh)
- Tamiya M05 A Part
- Tamiya M05 B Part
- Tamiya M05 c Part
- Tamiya M05 D Part
- Tamiya M05 F Part
