Go Back   R/C Tech Forums > International Forums > Singapore R/C Racers
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-07-2003, 12:20 AM   #1
pineapplet's Avatar
Arrow New Snake sneak peeks
this is not info from mytsn.. scooped off the rccaraction forums..
New features (front)
Some of the features of the new 710:
Front-
- quick change system for front transmission; you can change from front shaft, to differential or solid axles in a few minutes only
- front blocks with integrated belt-tension adjusters (eccentric)
- same length wheel-axles and drive-shafts front and rear
- re-inforced, long wishbones
- center shaft servo-saver system with adjustable spring-tension and Ackermann
- integrated mounting position for personal transponder
- adjustable steel track-rod
New features (rear)
- new geometry up-rights with high upper mounting position; adjustable camber and toe-in
- re-active rear suspension
- re-inforced, long wishbones; lower rear suspension arms with 2 mounting postions for the anti-roll bar and shocks
- adjustable rear ball-differential with easy external diff-adjustment
- quick change system for rear transmission; you can change from differential (standard) to solid axle in a few minutes
- rear blocks with integrated belt-tension-adjusters (eccentric)
- easy to use adjustable roll-center through nylon pivot inserts
- rear right bracket with new brake-position, creating better cooling
- disk-brake with steel disk and plates and excellent friction brake-material; cam-operated with auto-return spring-system
- carbon fibre upper rear plate
New features (centre section)
- carbon fibre side-plates with integrated ball-raced belt-tensioner
- lower engine mounting position
- side-mounted receiver position with protection case
- 75ccm fueltank with integrated filter, AFL-fuelcap and with special shape for low CG and rubber-mounted
- battery-pack mounted below fueltank, easy access through chassis-plate (battery not included)
pineapplet is offline   Reply With Quote
Old 11-07-2003, 12:48 AM   #2
pineapplet's Avatar
oops.. paiseh.. didn't see this already posted on TTC thread...
Forum Jump
Tamiya's sneak preview of the TRF416? sosidge Electric On-Road 61 10-07-2006 01:00 AM
Sneak Peak here hehehe supralative Painting, Designs, Graphics and Photography 9 11-20-2005 10:14 PM
HPI R40 Sneak Peak ***Pictures*** Accord Nitro On-Road 18 06-09-2003 10:09 AM
sneak preview of new magazine Cartman Web Links 0 02-06-2003 02:42 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
