Go Back   R/C Tech Forums > International Forums > Singapore R/C Racers
Old 12-23-2008, 08:37 PM   #1
Default Dualsky Track & Field series
Hi all,
After successfully launched the Race Pack, Dualsky is pleased to announce the new range of Brushless Motor.
Available soon....!!
Do check out our distributor in Singapore at
www.aerosmith-hobby.com
http://www.aerosmith-hobby.com/TF.html
Dualsky Advanced Power System.
* Dealership welcome.
Dualsky is offline   Reply With Quote
Old 12-27-2008, 05:07 PM   #2
Default XM540TF-3.5DF (direct series) Available
Hi All,
The Dualsky XM540TF-3.5DF (direct series -modified class for 1/10 car) is available.
Special Launched price at $95 ....!!!
Design : Sensored 3.5 Turns
Weight: 160 g
Motor Size : 540 size, 52.8mm * 36mm
Input Voltage : 4-6 (1.2v/cell) or 2s Lipo
Magnet : Sintered nickel plated , Neodymium
Shaft Diameter : 3.175mm
Watts / RPM : 620w/ 9330kv
Integrated with builit in rotor fan, adjustable timing, thermal protection
Check out our distributor at http://www.aerosmith-hobby.com
Old 12-27-2008, 09:28 PM   #3
Default XM540TF-5.5SF (sensorless brushless for 1/10 car)
Design : Sensorless 8.5 Turns
Weight: 160 g
Watts / RPM : 280w/ 6500kv
Price : $69
Available now in Singapore at http://www.aerosmith-hobby.com
Old 01-04-2009, 08:05 AM   #4
weikiat's Avatar
Weight: 160 g
Price : $69
Can this work with the Sidewinder ESC? How does it compare to cc's 5700kv motor? cos I'm looking around for replacement.. in case one day my motor thermal out. haha
weikiat is offline   Reply With Quote
Old 02-27-2009, 11:59 AM   #5
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Hi All,
Weight: 160 g
what ?! no 10.5? how bout a 13.5
cant even order an 8.5 . they look nice tho.. where are they made?
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 07-04-2009, 05:05 AM   #6
Default Dualsky Motor
There are various model for the motor.
Presently in Singapore, these are the 2 type available. They are available via our distributor from at "Aerosmith-hobby"
More information can be found "Dualsky website"
They are quality product from China.
Dualsky
Old 07-07-2009, 06:29 AM   #7
CAn i use my 60A esc on it???
Lakai is offline   Reply With Quote
Old 07-14-2009, 11:39 PM   #8
Default ESC to be use
We recommend using esc of 120A and above for the motors.
We are pleased to announce the launch of 2 new product.
XP50002TF 40C/60C - $129
XP42002TF 35C/50C - $89
Do check out our Singapore Distributor Aerosmith Hobby for more details.
Dualsky Track & Field series-xp42002tf-35c.jpg   Dualsky Track & Field series-xp50002tf-40c.jpg
Old 03-18-2011, 11:16 PM   #9
Default Dualsky Track & Field Z5 ...coming soon !!!
Items will be available soon !!!
Aerosmith is offline   Reply With Quote
Old 03-19-2011, 09:37 AM   #10
ali_g's Avatar
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 04-09-2011, 02:02 AM   #11
Default The new 6000mah 60C Track & Field XP600022TF
Aerosmith Hobby
Old 04-30-2011, 06:33 AM   #12
ali_g's Avatar
Used by Atsushi Hara at the recent TITC!!!
4.5, 5.0, 5.5 and 17.5t motors in stock!!!
Optional Z5 internal fan in too!!!
☆ JU.C RACING ☆
Old 04-30-2011, 06:37 AM   #13
ali_g's Avatar
☆ JU.C RACING ☆
Old 05-04-2011, 06:41 AM   #14
Default Available Now at Aerosmith Hobby
Hi All,
Aerosmith Hobby are pleased to inform you that the Dualsky Z5 and the latest XP600022TF 60C is available now in our Shop.
Please drop by to have a look at Fook Hai Building.
Aerosmith Hobby
Old 06-16-2011, 01:11 PM   #15
Default question on motor purchase
Hi aerosmith me newbie so not too sure what I bought
I was looking for a sensored motor and i.bought the motor from u....
When I.opened it up I realised that it was a sensorless motor.
The box specs are
Xm540tf-13.5S
Says sensored timing adjustable
Item 53353
But on the physical motor there is nothing that can fit a sensor wire and the box had no sensor wire.
I search for item 53353 but its a diff motor. ....
Also to run this motor there is no continuous output so I also dun know wat esc to pair with it. I only have 60a esc. This motor only 2500kv. So can a 60a esc be.enough?
Pls reply thanks.
Jeremy
jezzadazzler is offline   Reply With Quote
