TOTAL HOBBY INDOOR RACE @ PLAZA PELANGI | 22 & 23 NOV 2008
#17
JO,
Some question just pop up on mind...
1) For the Mini Enduro Fun Race,will transponder took place? If yes...will the transponder last for 1 hour timeline?
2) Same tyre rule?
Some opinion...
1)Why not TT01 and Mini pun into one category for the fun race...much more challenging and tactical....
2) Same tyre rule?
Some opinion...
#18
Rules & Regulations
A) Stock TT01
- Tamiya TT01 4WD
- 540 silver can (Mabuchi / Johnson)
- Standard ESC
- NiMh sub c 6cells (Max: 4600Mah) - stick / saddle
- Spec Tires (Available at Total Hobby)
- Open Body Shell (190mm)
- NO Traction Compound & Tire Warmer
- Min weight: 1500gm w/o transponder
- Min height: 5mm
B) M-Chassis
- Tamiya 2WD M-Chassis
- Tamiya Black Motor / Silver Can
- Open ESC (Brushed)
- NiMh sub c 6cells (Max: 4600Mah) - stick pack only
- Tires - as long as for M-Chassis
- Open Body Shell (For M-Chassis only)
- Traction Compound & Tire Warmer allowed
- Min weight: 1200gm w/o transponder
- Min height: 5mm
C) Open 23T
- Open Brand - 4WD 1/10 EP Chassis
- Tamiya 23T (RZ / TZ)
- NiMh sub c 6cells (Max: No Limit Mah)
- Open Tires
- Min height: 5mm
D) Endurance Rally TT01 (1hr 1man obstacles course)
- Tamiya TT01 2WD / 4WD
- Open ESC
- 3packs x NiMh sub c 6cells (Max: 4600Mah) - stick / saddle
- Open Tires
- Open Body Shell (190mm) - preferably rally b/shells
- No Traction Compound & Tire Warmer
- Min weight: No Limit
- 10 cars only!
E) Mini Endurance (1hr 1man obstacles course)
- Tamiya M-Chassis 2WD
- Open ESC
- 2packs x NiMh sub c 6cells (Max: 4600Mah) - stick / saddle
- M-Chassis Tires
- MINI Body Shell only
- 10 cars only!
HAVE FUN!!!!
A) Stock TT01
- Tamiya TT01 4WD
- Standard ESC
- Min height: 5mm
B) M-Chassis
- Min height: 5mm
C) Open 23T
- Open Tires
- Min height: 5mm
- Open ESC
- Open Tires
- 10 cars only!
- Open ESC
- M-Chassis Tires
- 10 cars only!
HAVE FUN!!!!
#19
JO,
2) Same tyre rule?
Some opinion...
2) Same tyre rule?
Some opinion...
2) NO, different tires will be run for each class & YES, no traction & tire warmer allowed
3) Imagine if you race a MINI with a Ferrari? Who will have a better advantage? Besides, if u decides to join both class, then which car you would run?? Most likely a TT01.
The objective of the fun race is to have FUN!!! We hope to promote both class to all,both drivers and spectators and we hope every1 can join in. It would be just like your practice or bashing time, only thing with your lap time being recorded. There won't be any trophy. Just some fun time. While we are thinking RM10 entry fees only.
One most important thing about the fun race I forgot to mention, we can only run 10 cars max! So better sign in early!
#20
Is it a open tyre for all category or it will be restricted as well.
Defined No Jo,I will run the MINI to promote it,because not many of TAMIYA JB has it...they afraid of the FRONT WHEEL Basist...since the max is 10 machine only...why not we put it this way,if each class of fun race has 10 machine,done we run 2 class...but if tak cukup,then we combine it TT01 n MINI... Just an opinion from me only....Thanks Mate..!!!
#21
Maybe you can run both class together the at final result u split according to cls.Just my suggestion
#22
one more thing jonest....when u say this :
- Open ESC
- M-Chassis Tires
- MINI Body Shell only you really mean only mini cooper body right??? really hope not....
- 10 cars only!
- Open ESC
- M-Chassis Tires
- 10 cars only!
#23
pls consider
I have some suggestion, can the organiser create another open class* category? I have about 12 racers who would like to participate as none of us have any 23T Stock motor.
Open class * Open motor (brush/brushless), battery (NiMH/Lipo), tires (any type or brands) etc. Control only on minimum 1500g weight, 190mm track width and saloon bodyshell. Lets call it a year end speed bashing.
#24
SUNDAY RACE (23 NOV 2008)
A) TT01 STOCK TOURING
Name / Frequencies
1) Jonest
2) Normac
3) Najib / 2.4Ghz
4) Han Anthony / 2.4Ghz
5) Rudy / 2.4Ghz
6) Has / 2.4Ghz
B) TAMIYA M-CHASSIS
Name / Frequencies
1) Jonest
2) Najib / 2.4Ghz
3)
C) TAMIYA SUPER 23 STOCK
Name / Chassis / Frequencies
1)
2)
3)
4)
Saturday Fun Race (22 Nov) Entrance Fees (TBC)
D) Endurance Rally TT01 (1700 - 1800)
1)
2)
3)
E) Mini Enduro (2000 - 2100)
1) Najib / 2.4Ghz
2)
3)
Hope to have more entries by the end of the week...
Pls update that participants withdrawn from Tamiya Super 23 Stock, however there is now 14 participants waiting for open class.
Name / Frequencies
1) Jonest
2) Normac
3) Najib / 2.4Ghz
5) Rudy / 2.4Ghz
6) Has / 2.4Ghz
B) TAMIYA M-CHASSIS
Name / Frequencies
1) Jonest
2) Najib / 2.4Ghz
3)
1)
2)
3)
4)
1)
2)
3)
1) Najib / 2.4Ghz
2)
3)
#25
- Open ESC
- M-Chassis Tires
- 10 cars only!
- Open ESC
- M-Chassis Tires
- 10 cars only!
However, if majority would like to call for open b/shell, we shall consider it.
#26
YES, let's have a MOD Class. But to make the race fair and exciting, we could consider follow rules from Reedy Race:-
1) All chassis must be 4WD sedans
2) All cars must have 4-wheel braking and four-wheel drive at all times. No one-way bearings allowed.
3) Traction compounds are legal. Setting fire to tires for traction is prohibited.
4) Tire warmers are legal.
5) Drivers have the option of running 5-cell NiMH, 6-cell NiMH or any ROAR approved hard case LIPO.
6) Minimum car weight: 1450 grams for 5-cell Nimh equipped cars, 1525 grams for 6-cell Nimh equipped cars, and 1525 grams for approved 7.4V LiPo equipped cars.
7) B/Shell: 190mm 4-Door sedans.
8) LiPo battery voltage must not exceed 8.44v when measured in tech before the race.
With the above arrangements, the race should be most exciting.
#27
Name / Frequencies
1) Jonest
2) Normac
3) Najib / 2.4Ghz
5) Rudy / 2.4Ghz
6) Has / 2.4Ghz
B) TAMIYA M-CHASSIS
Name / Frequencies
1) Jonest
2) Najib / 2.4Ghz
3)
C) OPEN MOD CLASS
1) So we should have 14 entries! cheers
2)
3)
4)
1)
2)
3)
1) Najib / 2.4Ghz
2)
3)
Name / Frequencies
1) Jonest
2) Normac
3) Najib / 2.4Ghz
5) Rudy / 2.4Ghz
6) Has / 2.4Ghz
B) TAMIYA M-CHASSIS
Name / Frequencies
1) Jonest
2) Najib / 2.4Ghz
3)
C) OPEN MOD CLASS
2)
3)
4)
1)
2)
3)
1) Najib / 2.4Ghz
2)
3)
#30
Name / Frequencies
1) Jonest
2) Normac
3) Najib / 2.4Ghz
5) Rudy / 2.4Ghz
6) Has / 2.4Ghz
B) TAMIYA M-CHASSIS
Name / Frequencies
1) Jonest
2) Najib / 2.4Ghz
3)
C) OPEN MOD CLASS
01) Kenny / HPI Pro4 / 40.975
02) Rudy / Tamiya TT01E / 2.4Ghz
03) GC Wong / HB Cyclone TC / 2.4Ghz
04) Shawn / HB Cyclone TC / 2.4Ghz
05) Azahar / Xray / 67.00
06) Enal / Xray / 26.886
07) Lonjong / Xray / 27.225
08) Abdi / Xray / 2.4Ghz
09) Kelvin / HB Cyylone / 2.4Ghz
10) David / HB Cyclone / 40.480
11) Simon / HB Cyclone / 2.4Ghz
12) Ah Huat / Serpent S400 / 40.680
13) Mamat / Tamiya TBEvo / 40.610
14) Acang / Tamiya TA04R / 27.228
15)
16)
17)
18)
19)
20)
1)
2)
3)
1) Najib / 2.4Ghz
2)
3)
Name / Frequencies
1) Jonest
2) Normac
3) Najib / 2.4Ghz
5) Rudy / 2.4Ghz
6) Has / 2.4Ghz
B) TAMIYA M-CHASSIS
Name / Frequencies
1) Jonest
2) Najib / 2.4Ghz
3)
C) OPEN MOD CLASS
15)
16)
17)
18)
19)
20)
1)
2)
3)
1) Najib / 2.4Ghz
2)
3)
