TT01 - E
#31
PLs help!!
Hi, im a newbie to rc. and i am playing TT01-D and i have hop up the alu shaft, steering link, turn-buckle and the carbon deck frame. And i bought the TT-01E's fixed arm as i prefered fixed one than the adjustable ones. Is it necessary to change the universal shaft ? because my dogbone happens to drop a few times when i play touring for fun sometimes. And anyone can advise any hop ups for my TT01-D? Thanks =)
#32
ball diff is better than gear diff in term of many ways, very smooth and nice to handle. its worth to buy if you have $$ to spend
but need extra maintenance than gear diff.
#33
from your other question, it will be helpfull if you will be precise.
whats your purpose in upgrading your kit, are you a racer or basher?
but for me a good servo, analog or digital would give you extra point whether you a basher or racer.
#34
The universal shafts helps in running.running as in? I just bought the Novak XBR and the 8.5T EX motor for my TT01-D. Some thinks it's too much for TT01 but I use it for super drift. And my battery that I got it when i just bought my TT01 is Sanyo 2400.I feel the punch is not as good as maybe Team Orion's 3300,4500 etc.and the battery use up very fast.haha.
#35
Hi guys, I'm new and am very interested in r/c cars. But til date I still can't make up my mind as to which models and brands of cars should i get. I like to ask, what's the difference between for example: TT01 and those TA01 etc series? Are they jusy a name for those newer chassis? Thanks in advance!
#36
Hi, for my opinion i would rather you get a TA05-R instead. After playing the TT01-D , I realised I prefered the TA05-R instead. haha.
#37
...or if you prefer 'shafties', you now have a choice ...get the TB03 IFS
dun have to worry about stones chewing your gears and belts plus that Garaiyah bodyshell is a KILLER !
#38
The TT01E bearing set has two additional type 850 bearings. Where should these be installed if I want to upgrade my TT-01 to Type E config?
Thanks!
Thanks!
#39
#40
Compatibility Issues
Will the TT-01E A parts and B parts (specifically the steering assembly) be compatible with The TT-01 Tub Chassis? I love my Old TT-01 but the wobbly steering is really freaking me out.
How about TA-05 steering set compatibility to TT-01?
