I have RC stuffs new in box/pack for sale.
Do contact me @ 96457589 if interested.
A22-10S brushless motor - $40
Shaft Size: 3.0mm x 12mm
Motor Dimensions: 28mm x 29mm
Weight: 49g
Specifications RPM / V (Kv) : 1200
Battery : 3 Lipo
Operating Current (Amps) : 4-13
Peak Amps (15sec) : 16
Prop : 9 x 5
A22-15M brushless motor - $45
Motor Dimensions: 28mm x 34mm
Weight: 67g
Specifications RPM / V (Kv) : 1050
Battery : 3 Lipo
Operating Current (Amps) : 6-16
Peak Amps (15sec) : 20
Prop : 10 x 5
A22-20L brushless motor - $50
Motor Dimensions: 28mm x 39mm
Weight: 85g
Specifications RPM / V (Kv) : 1000
Battery : 3 Lipo
Operating Current (Amps) : 8-21
Peak Amps (15sec) : 25
Prop : 11 x 5
All the above comes with below accessories:
T Plug 40Amp: 1 pair for $2.50
Highly efficient, lightweight, high-power connector. Used on high discharge li-poly battery packs.
TowerPro MG995 Metal Gear Servo: 1 for $30 (4 for $100)
MG995 metal gear 13KG large torque
Connector wire length:320mm
Weight:55.2g
Operating speed:0.24sec/60degree(6.0V)
Stall torque:13.0kg/cm or 180oz/in(6.0V)
Temperature Range:-20 degree to 60 degree
Dead band width:4ms
Operating Voltage:4.8V~7.2V
Structure Feature: 3 pole ferrite, dual ball bearing, 3 metal gears and 1 Resin metal gear,
connector wire length: 32cm
Recomended for cars/trucks or boats use.
TowerPro SG90 micro Servo: 1 for $12 (4 for $44)
Coreless Motor, All Nylon Gear, Wire Length 150mm
Weight: 9 grams
Dimensions: 22mm x 11.5mm x 27 mm
Operating Speed (4.8V no load): 0.12sec/60 degrees
Stall Torque (4.8V): 17.5oz/in (1.2 kg/cm)
Operating Voltage: 3.0-7.2V
TowerPro SG50 micro Servo: 1 for $12 (4 for $44)
Coreless Motor, All Nylon Gear, Connector Wire Length 150MM
*Dimensions: 20.9mmX11.4mmX22mm
*Operating Speed (4.8V no load): 0.10sec/60 degrees
*Stall Torque (4.8V): 10.2 oz/in (0.7 kg/cm)
*Temperature Range: -30 to +60 Degree C
*Dead Band Width: 7usec
*Operating Voltage:4.0-7.0 Volts
Mystery 2200mah 15C 3s: $50 (2 or more for $45)
Size: 100mm x 34mm x 25.15mm
Capacity: 2200mah
Voltage: 11.1v
Continuous Discharge Rate: 15C
Charger Time: about 2.5 hours (by input 1A)
Mystery 2100mah 20C 3s: $55 (2 or more for $50ea)
Size: 100mm x 34mm x 25.16mm
Capacity: 2100mah
Voltage: 11.1v
Continuous Discharge Rate: 20C
Weight: 160g
Mystery 1500mah 15C 3s: $40 (2 or more for $35ea)
Size: 62mm x 31mm x 18mm
Size: 100mm x 34mm x 25.13mm Capacity: 1500mah
Voltage: 11.1v
Weight: 100g
Mystery 900mah 15C 2s: $25 (2 or more for $22ea)
Size: 51.3mm x 29.5mm x 13.8mm Capacity: 900mah
Voltage: 7.4v
Charger Time: about 1 hours (by input 1A)
Weight: 43.4g
