How to determine the peaking mAh of a battery
Hi guys and gals recently got myself a Team Orion advantage charger with lipo charging capabilities and how to check the peak mAh for batteries with this charger cos while charging my brand new LRP 5 cells 1400mAh battery it shows 700 plus mAh after one cycle (discharged and charged ) another question I would like to ask is about the internal resistance of a battery is it higher the better or lower the better.
new batteries tend to require a few cycles of charge/discharge before their full capacity/performance is reached...
after using a few times, u shld see yr new battery peaking higher.
