Tamiya Asia Cup Qualifying Championship 2007
#16
Originally Posted by hoppie
I have a question, for M-series class, what kind of shocks is approve and normally used? Can TRF shocks be used?
anyone correct me if am wrong, it been a long time since i touch my mini..
#17
any mini racer care to share? I mean using CVA with spacer abit troublesome right? Are you guys using TRF dampers?
#18
#19
Originally Posted by foampervert
i've bought myself a new high toque servo saver and ima gonna try that, then the spring on the servo saver trick, then the cable tie...
thanks for the input! i do appreciate it!
-alexander
-alexander
For the shocks, what M&N meant was the internal spacers to reduce droop for the M03. CVA super mini shocks are preferred due to its shorter shock body which many of us felt gives better damping. And yes, we are stuck on using plastic spacers to adjust preload.
#20
Originally Posted by GKC
Just use the largest ring from the high torque saver will do, no need for the cable tie.
#22
Originally Posted by Tommi Makkinen
is that confirmed bro? so the TAC final in Taiwan will not have this class?
yikes!!!! i think i committed to the wrong bloody category!!!
#23
cheers..
#25
Hi guys! I would like to ask if it is allowed to use tape to hold the battery in M03 chassis rather than using the quick release batt holder? Because I am using the batt holder from my twin dagger... I don't have the original one for my M03
Thanks!
Thanks!
#26
Thanks!
Thanks!
#27
in the stock touring class, must be batteries be connected to the esc using the tamiya connector?.. is deans plug allowed? i noe the motor must be connected by tamiya plugs but none is mentioned about the batteries unless i missed out..
#28
cheers
#29
Originally Posted by M&N
hi egaabwaa, there isn't any restriction on the choice of connector used for the battery, as long as the battery is in stick form.
cheers
cheers
#30
Originally Posted by Bugs Bunny
M&N, i think for local race can use any kind of plug for e stock class stick pack battery. But for e ASIA CUP, u have to use tamiya plug.
since we allow all type of battery as long as it's in stick form, we allow the different plug as well.
as for those beginners don't worry just join in and have fun.
there r lots of friendly driver willingly to assist during the race day
especially Bugs Bunny a friendly and helpful guy.
description: a bit round, wear spec, alway wear red T-shirt.
cheers
