Pipe/Engine Query
#31
Pipes pipes and pipes.....
hmmmm......learnt quiet a lessons....guess me too got a certain pointer next time buying pipes....
bottle.... SGG-5 really good eh ???? den must start save $$ liao....
#32
Originally posted by Joehwee
bottleneck:
Longer pipe length = better torque
Shorter pipe length = high speed
bottleneck:
Here's the summary so far
High speed = high end = shorter length = smaller divergance angle
High torque = low end = longer length = larger divergence angle
More to add??
How about diameter of belly?
Fatter belly = better torque
Slimmer belly = better high speed
EiKuD
eh .........
Based on the anlogy here and what I see on the tracks, I would say it is a good pipe to have ..... so is 5star, novarossi, CVEC, Zac.... (to be fair to other pipes)
Been doing some reading, trying to find out which pipe is best for my engine, track, weather bla bla bla...... There is no such thing as a perfect pipe
So, end of the day, have to buy one and try Inventory goes up and $ goes down
Another thing to do is to suck some experiences from the experts.
Thanks you all for the info so far.
Shall keep sucking for more info.
Cheers
#33
Bottle...i couldn't agree anymore further than what you say...indeed want to know the performance must buy and use it..
hey i got lobang for some pipes....check your PM
#34
Shorter Stinger = higher speed
longer Stinger = better torque
But Ifmar have a restriction on minimun Stinger length.
But I believe the manifold also make a difference.
And I have being looking for the RB #1351-02P conical Manifold but no-where got stock......
#35
Can anyone recommend a good pipe around $50-60?
Also please state whether its more for torque or top speed and where I can get it.
thanks
thanks
#36
Wah pian .....
Stinger length also make a diff
If IMAR has a restriction on the min stinger length, so, the shorter the better?
How about no stinger?
Speaking of no stinger, how about dented pipes? Is there great difference in performance?
When I've got lots of dents, the car feels slightly sluggish. Maybe engine requries tuning.
After operation freezer, performance is better than dented, but not as good as new.
Maybe should look for a tougher pipe that don't dent so easily
Hi EiKuD
Hopely can get comments on a wide range of pipe here
This is a definately a win-win-win suitation
Pipe owner wins - everyone else win - lhs biggest winner
Cheers
Hi EiKuD
Cheers
#37
Also even there are no dent, as carbon built up in the pipe, the performance also drop.
And some pipe have very high back pressure which will make you tune the engine very lean which is not good.
There are so many things about pipe.....so for me, just use the cheapest and most popular pipe.
#38
Pipes
Hi, I have tried Kyosho, ZAC & SGG5. These have been tried with diff. engines in PA & MS. From what I noticed is that a particular pipe behaves differently with different engines, tuning & tracks.
Personal opinion is to get an all-round pipe that provides respectable grant throughout the powerband so that you could enjoy yourself at any of the local tracks with some minor fine tuning of the engine to control the characteristic here & there.
Hope this is useful!
#39
learnt some lessons here. Good thing no need schools fees
Now looking at ways to save $
Anyone tried to modify the pipe?
Something like shortening the stinger and inlet?
Got improvement?
Oh.... does adding a exhaust deflector affect performance?
Does carbon build up in the pipe?
Is it like 2-stroke motorcycle that carbon deposit can be found on the piston and exhaust pipe?
So far yet to see any carbon build up on my piston. Not sure about the pipe, can't see la...
Cheers
Got improvement?
Cheers
#40
Originally posted by ART2
Well all I know is that a bigger stinger produces very loud engine sound but not neccesary fast, look for a pipe that gives you enough power and in the same time saves fuel is your priority.
Got any tips on what type of pipe design saves fuels?
I always believe that power up, fuel efficiency down and via versa. Either ends are no good.
Cheers
#41
[QUOTE]Originally posted by Bottleneck
got one way....modify engine to run with fresh water lor....
#42
Originally posted by Nipple
What I mean was the stinger must not be shorter then a specific 'minimun length'.
True, when the pipe is dented, even when you recover it, the performance drop.
The material will affect the performace too. softer pipes have better all round power due to less restriction to expandsion.
I just think to the extreme... let my imagination run wild and out of the box, but most of the time not realistic
Here's another one
Softer material is better due to the ability to expand. A good high speed pipe will end up a good high torque pipe after some running True?
Cheers
#43
[QUOTE]Originally posted by EiKuD
Fresh water is going to be ex
Try sea water.....
Try sea water.....
#44
fresh water ? why not new water ???
haiii...talking about so many pipes..... so many tips....also ownself use ownself syok....
do you guys realise quiet some time no GP race liao ???? for 1/10 lah i mean in singapore.... maybe i got i sleeping ???
#45
Here's another one
