1. GPM Reservoir shocks
- blue anodized
- new in pack
- 2 packs for sale (total 4 shocks)
- measure 10.5cm from mounting point to mounting point
- functional reservoirs for more consistent damping
- comes with rubber boots for dust protection
- threaded bodies for preload adjustment
Price: SGD75 for all 4
2. Aluminum Knuckles for CLODBUSTER or TXT
- blue anodized
- new in pack
- have a few sets for sale
- replace the plastic knuckle which is prone to breaking with these aliminum upgrades
- comes with all mounting hardware
Price: SGD40 a pair
3. Monstertech sliders for TLT/Max-Climber trucks
- new and unused.
- Replaces stock drive cups and dogbones with machined outdrives and Traxxas slider shafts!
- Universal joints reduce backlash for more efficient drivetrain
- At the same time, joints allow for greater adjustability of ground clearance (from stock 0.8"/2cm to 1.6"/4cm approx.) without binding - almost 100% increase in clearance!
- Slider shafts are durable but also allow easily adjustable wheelbase - run stock or lengthen your truck, driveshaft length is no longer a limitation!
- Diff joints are designed and machined to allow maximum articulation by positioning universal joint as close to the differential as possible.
Price: SGD70 for a set (enough for one truck)
4. Brace for Thundershot/Thunder Dragon/Fire Dragon/Terra Scorcher
- something for those running these older buggies.
- brace will prevent the weak A5 part from breaking.
- all hardware included, no mods necessary.
Price: SGD30 each.
