Xray X10 to WGTR
I will assume that ride height needs to be addressed. Spec for the class is 5mm minimum. The tires are tall so you might need shimming to get close to that. I don't know how X-Ray adjusts rear height but on a car that accepts Associated type adjusting inserts, just find a set of #4. The front end will need about 2.5 to 3mm of extra shim. Don't forget to set the servo height for the front end change.
Heard people were using X1 motor plates with the pill imserts.
Some parts from Fenix for the Xray 10-2018 and 2016:
Chassis brace:
Motor shoulder brace:
Chassis brace:
