Tamiya M-07 Concept
#301
My set-up from the Jackson TCS Race. Medium grip asphalt about 80 degrees.
Front: Yellow springs / 40wt / 3-hole piston / 5mm ride height / red sway / -1 camber / -1 toe out / premounted spec tire sgrip - lite glue side wall
Rear: Blue springs / 40wt / 3-hole piston / 5mm ride height / red sway / -1 camber / no shims on toe in block / sgrip premounted
reedy 21.5 spec motor / 20t pinion / 1330gram
Qualified 4th and finished 4th... overall a good race but lacked top end speed compared to others. Car was too easy to drive, needed to make it looser. Used a ball diff set tight but still had diff action. I will try a gear diff next time out.
Originally I had the stuff that came with the kit, but that didn't do anything for me. So I jumped it up to 1 mil, (The most John had) and it made it abit better but I was still really slow and the diff still felt funny!
#302
I installed the anodized blue aluminum steering turnbuckle. The anodizing is not hard at all. A little rubbed off the first time I put a wrench on it. Bummer.
Secondly, I thought the line or notches on turnbuckles always were on the left hand thread side. In this case it seems to be on the right hand thread side. Is my memory wrong?
Lastly, while wrenching I noticed a lot of play in the front suspension. I have the spacers installed. This seems to be too much. More than I'm used to for sure. See the video. Is there a way to tighten this up?
+ YouTube Video | |
#303
Right now I have a 0.2mm shim between the knuckle and c-hub for removing up/down play.
#304
Thank you! I like bling. That's why they caught my eye!
Besides looking awesome, I don't think they serve much of an actual purpose. They would, in theory, save your body from a little wear since riding on body clips is harder on a body than riding on a larger platform, but they are probably just bling.
Another thing I noticed that the threading would allow more precise body heights that would normally fall in between body clip holes.
I found this which explains how they mount.
#305
On my HPI RS4s and Tamiya DF-03Ra's I opted to get aftermarket caster blocks with ball-bearing kingpins, but I haven't found a good set for normal Tamiya touring-cars.
#306
Finally have all the electronics installed. Had many TBLE02S escs laying around so I took one, opened it up and did the lipo cutoff mod and blacked out wires. Paired it with a Hobbywing V10 21.5 motor, the tabs and sensor cables fit nicely without need for any grinding of the chassis.
Now just gotta paint up the Mazda Demio body and hopefully hit the track next weekend.
Link to the mod for those who are interested:
http://laneboysrc.blogspot.com/2015/...o-cut-off.html
#307
LANE Boys RC: Tamiya TBLE-02S mod for LiPo cut-off
#308
42102 TRF Special Dampers with M07 kit springs.
I've tried the 54000 M-Chassis set with short shafts + long rod end, long shafts with short rod ends but I either not get enough ride-height (like 2mm) or the springs would have be cranked all the way down leaving no adjustability.
So far I prefer these regular length dampers as I can get the car around 4-5mm with room to go lower or higher.
Edit: I'm running 55mm tires, hence the ride-height issues I'm getting with the M-sized dampers.
#309
This is my first M chassis and i'm using blitz mini gti body that listed 225mm. The body fit nicely according to the wheelbase but i think it's too wide. Nearly 10mm left and right. Anyway it's an easy to drive body and chassis
#310
#311
Body mounting
Trying to transfer my JCW body from m-05 to my m-07
Do I need to drill new holes for the rear in the body or did I miss something?
#312
I drove my M-07 more tonight with the swaybars. I'm running red/soft up front and in the rear. It's developed a push and also a behavior where it's constantly losing and regaining traction in corners. The front end is basically stuttering as it loses and regains traction. I don't like that at all. It's more difficult to prediction.
I think I'm either going to disconnect the front sway bar or install the blue/hard bar in the rear.
#315
I received my hole plug in the mail today,
Quality seems very nice and the fit is perfect!
here is a photo..
here is a photo..
