Like Tree759Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 12-04-2017, 07:18 AM
  #1141
Trader Rating: 65 (100%+)
Hopefully you can read my chicken scratch.
On this one I played with upper links but it took some steering out
Prior to this upper links in stock positions and lowers as they are shown are good.
I’ll end up somewhere in the middle after more testing.
Antimullet is offline
Old 12-04-2017, 09:25 AM
  #1142
snuvet75's Avatar
Trader Rating: 16 (94%+)
Originally Posted by Antimullet
Attachment 1452325
Your car's front arms angle forward. How's that working out for you? And the rear arms angle rearward. I noticed that Hara put angle in the back like that once but not in the front.
snuvet75 is offline
Old 12-04-2017, 03:30 PM
  #1143
Snuvet the diagram is misleading and IMO labeled wrong. They are actually not pointing in or out. They are all wider and higher pin settings I just filled the dots in to read the proper label of +0.5 etcetera.
The labels should all have positive or negative on the same side and they don’t so it’s a jacked up drawing on the setup sheet.
I’ll go see if I can modify the setup sheet in the am and post an electronic version.
GrandeGixxer likes this.
Old 12-04-2017, 04:42 PM
  #1144
snuvet75's Avatar
Oh I remember you guys talked about it vaguely months ago. So what you're saying is the diagrams for the inserts is the view from the front for FF and the rear for FR?
Antimullet likes this.
snuvet75 is offline
Old 12-04-2017, 05:49 PM
  #1145
EDWARD2003's Avatar
Originally Posted by The Teacher
So after another awesome night of racing with the MTC1 I find myself with a serious problem....I need more corner speed!!! When I look at video of my car vs other fast cars it looks as though my car does not transition from side to side fast enough. I'm thinking thicker sway bars might help but wanted to see if anyone had any thoughts??? Currently I'm running on black CRC carpet, super high bite. I'm running 600cst oil with 4 hole pistons with progressive 2.5 - 2.8 springs up front with 2.6 springs in the rear. What do you guys think...?
For more corner speed I would drop the differential oil down to 3k.
EDWARD2003 is offline
Old 12-05-2017, 02:10 AM
  #1146
Exactly snuvet!
snuvet75 likes this.
Old 12-05-2017, 10:18 AM
  #1147
snuvet75's Avatar
IMHO, If you are talking about esses, thinner shock oil. If general corners, it sounds like scrubbing but more detail would be needed on which section of corner u have trouble, if the car pushes or oversteers,etc.
snuvet75 is offline
Old 12-06-2017, 02:26 AM
  #1148
GrandeGixxer's Avatar
Trader Rating: 21 (100%+)
The Racing Shop - racing factory Mugen A2502 - MTC-1 - Mugen verstärkte Dämpferbrücke hinten Carbon A2502-trf-MTC1
New rear shock tower
GrandeGixxer is offline
Old 12-06-2017, 03:10 AM
  #1149
Regional Moderator
disaster999's Avatar
whats so special about this "new" shock tower compared with stock?
disaster999 is offline
Old 12-06-2017, 04:44 AM
  #1150
Thicker
disaster999 likes this.
Old 12-06-2017, 05:15 AM
  #1151
LOW ET's Avatar
Trader Rating: 109 (100%+)
is there a problem with the stock towers breaking?
LOW ET is offline
Old 12-06-2017, 06:59 AM
  #1152
I think it’s more of a flex issue.
Old 12-06-2017, 05:30 PM
  #1153
Regional Moderator
Mine started to delaminate at some parts, probably from flipping over too much. Ive soaked it with CA and clamped it tight and seems to be holding for now. A thicker shock tower should withstand flips much better
Old 12-07-2017, 01:04 PM
  #1154
carkillaii's Avatar
Hey Guys not sure if this was talked about , the inner lip on my caster blocks have sheered off , I don't recall having any hard crashes is this normal?
The Teacher likes this.
carkillaii is offline
Old 12-07-2017, 01:41 PM
  #1155
Mine are both broken as well. Looking at the mechanics of things, I don’t know hat it has any effect?
The Teacher and carkillaii like this.
