Infinity IF14
#31
Infinity have officially introduced their new IF14 1/10th scale electric touring car kit. Originally based off of the SMJ CX11, the kit was refined with the help of Infinity’s factory on-road team that includes World Champions such as Marc Rheinard, Jilles Groskamp, Naoto Matsukura and Andy Moore to name just a few. The car makes use of a new, fully symmetrical chassis and topdeck design for precise steering action and equal traction characteristics while the somewhat unconventional suspension mount design has the lower arms attached to the front and rear aluminium bulkheads rather than the chassis as it is standard for most of today’s electric touring cars which results in a more natural chassis flex. Composite bushings make for swift and easy suspension geometry changes, such as toe and anti-squat, without the need for additional suspension brackets. Other suspension parts include low-profile big bore shock absorbers with genuine SMJ springs, the kit utilities 1-piece or split-type anti-roll bar mounts for easy to tune and maintain swaybar action and red anodized aluminium turnbuckles make for visual impact. Also included are newly designed double joint front driveshafts, a floating aluminium servo mount, alloy battery mounts, 20T aluminium center pulley and a zero-gap foam front bumper. The kit, that already has proven its capabilities by winning high-class races such as the recent opening round of the AOC, is set for a release around mid-May.
Features
* Aluminium suspension holder directly mounts to the 7075-T6 lower bulkhead for unhindered chassis flex
* Resin eccentric bushings for easy toe angle and anti-squat adjustments
* Short big bore shocks and SMJ silver line spring
* Newly designed D. J. CVDs in the front as standard
* 2.25mm-thick main chassis and 2.0mm-thick top deck
* One piece type & split-up type sway bar holders
* Red anodized lightweight aluminium turnbuckles
* Aluminium battery holder
* 20T Aluminium center pulley
* Front axle: Rigid axle (38T)
* Rear differential: Gear differential with oil encapsulated (38T)
* AXON spur gear TCS (64 pitch) is included
* Second speed reduction ratio: 1.9)
RCMart have it on preorder for $549.90US.
Features
#32
Can preorder it here in the states for $509.00 https://ultitires.com/index.php?rout...y&path=189_240
#35
Manual is up!
http://www.infinity-rcshop.jp/pdf/99...ION_MANUAL.pdf
A few changes so far from the CX11. Bearing swaybar holders are now screw mounted instead of integrated into the bulkheads. 4 screws for the shock towers, and hopefully the motor is dropped a bit since the chassis is now relieved for it.
Mike
Mike
#37
First lot was sold out
Spare parts arrived
2nd lot next week arrive !
Spare parts arrived
#38
Regional Moderator
Kits is starting to show up in our LHS and someone already started building it. Pictures are taken from a local forum. Hope this appears for everyone.
My initial impressions is they didnt really do much with the car. Basically a bone stock SMJ CX11 with different color anodizing. Separate bolt on swaybar mounts, holes for a chassis mounted steering arm, and battery mount with integrated battery strapping holes. Aluminum turnbuckle and rear CVD shaft instead of spring steel.
#39
Don't forget the holes in the chassis to make running an Xray T4'17 motor mount easily....
#40
Gold screws with red turnbuckles? I've just had to stab myself in the eyes so I never have to look at that again.
#42
I use T-Works gold plated steel screws in all my cars which are mostly Xray so they clash horribly with the orange but at least I can see the damn things.
