High traction carpet TC setups
I know that petit rc has setups on it, but I am looking for some insight on some gurus in the TC lane as there's this one track that's beating my brain as to get a setup for it as it's the only track i've been to with THAT much traction and i havent been able to get the car to do what i've wanted.
Destiny RX-10S - Bryan Thomas - Bush River Raceway - 12.03.2017
This is my general setup. Things i tried manipulating was a one step higher stiffer springs, adjusting front toe and camber, ride height and droop. I was still lacking a lot of entry steering and mediocre mid steering, exit steering wasnt bad at all. I was able to get my back end to step out how i wanted (which is more of my style of how i like to drive tc).
I've looked at some Yokomo setup sheets and there's few on the BD8, but the BD7 has something that's synonymous throughout which is heavier diff fluid and slightly heavier shock oil.
Anyone have any input they'd like to spill onto me, please? Thanks in advance
Not a guru and stating the obvious but would a more agressive body help?
Other setup things you can do to help would be to stand your rear shocks up a little bit or remove a bit of toe in on the rear.
Roll Center can also impact this, but I don't feel confident enough in my understanding of roll center and how to tune it to give advice yet.
sorry...i did mean to mention that i switched out this week with a Bittydesign Nardo, it was more aggressive than the Mazda 6, but not stable. I will be trying out the Bittydesign M410 assuming that it's a bit more aggressive but as stable as the 6
I had the same thought. Something like the Protoform Camaro ZL1 might help out with getting a bit more rotation while remaining predictable.
I had the same problem with 3 degree rear toe in: the car is scrubbing speed bad.... I went down to 0 degrees, but have not made it to the track yet.... I have heard great things about 0.5 degrees rear toe in though...My zero degree setup fluctuates between 0 and 0.5 degrees with suspension play anyway...
I would also watch kevin kane's video on youtube on going from asphalt to carpet... Lots of info there... I don't have the link, but I think you can find it easily by search rc car carpet setup on youtube...
One last thought, maybe you can try increasing your rear droop a bit to transfer more weight forward on braking. You may get a bit better entry and mid corner stability. If your exit stability is good, don't touch the front droop.
i messed with rear droop and that didnt give me the effect that i was looking for. fast lap and top 15 remained the same pretty much the entire day. i appreciate it tho
Yea, I've thought about getting a front diff putting a mill and some putty in the front diff. i'm nervous to lose the exit steering/rip out of the corner. also doesnt help that's its hard to get parts right now. I'll just have to order from rocherc and wait a couple of weeks, if they even carry the front diff
Phat, a few things you may want to consider:
Does the car run and steer well at half-speed laps and then only push at race speed? If so, I would bet money that your car is dragging the edge of the chassis as you dive into the corners, even if there is no residue on the chassis plate. If a much stiffer front sway bar makes the car more consistent this was probably your issue.
It is possible to have the car transfer too much weight to the front to steer effectively. Reducing your ESC's drag brake, taking out the rear droop, or shifting your battery back may help rotation as well.
I also think your roll center is too close to the lowest settings to give you enough responsiveness(less chassis roll) for carpet racing... You can try sliding the thinnest roll center shim under your A arms, front and rear, to increase responsiveness a bit from your current settings(asphalt settings)....
Also , a 2.6 spring in the front with a bigger swaybar might help....
For starters, I seen no one has mentioned glue on your sidewalls. Assuming this is high grip crc black carpet, how high are you gluing your tires? Your car will push everywhere if you are gluing too high. Second, your mid/exit push is most likely your diff. You need to be In the 8-10k oil range to keep from diffing out on the high grip carpet. Lastly, a speed 6 has less initial steering. I would recommend a montech is200. Very aggressive on entry yet still stable.
