New to RC, receiver/esc issue is discouraging. Help!
Hi Everyone!
This is my first post after lurking for a long time.
I have an issue where my RC takes off full throttle with no control after a few minutes of driving.
Heres my setup:
Ofna Jl10e
Hobbywing ezrun 9t/35a combo
Dynamite 1800mah 7.4v 6 cell nimh battery
Towerhobbies 2.4ghz rx/tx
This is my first RC. I set everything up, bound the receiver,set up the esc as well (did everything according to manual). Then I run it in the house on the carpet.everythings fine. I then take it out to the parking area and drive down about 30 feet. I turn it around to come back and give it some throttle and half way back it takes off on its own,full throttle, under some cars. I go to pick it up and its still going full throttle with a solid red light on the esc(which in the manual says that solid red means accelerating, but not full throttle).I turned the esc off then on again and everythings fine. This happens every time and I keep bringing it back trying to rebind and reset everything.
The first thing I thought was the battery is too weak or mabie the esc is reading for lipo, but i turned off that setting with the program card.
I am stumped.
I get about a 3 minute run in every time, but for that 3 minutes im free.lol. someone please help me extend my freedom to at least a full charge of battery.
Thanks!
Heres my setup:
Ofna Jl10e
I am stumped.
Thanks!
[QUOTE=TXNE;14829733
Heres my setup:
[/QUOTE]
By the stats this is a combination of disaster waiting to happen. Over powered under battery, your lucky to get 2 minutes.
Heres my setup:
[/QUOTE]
I know the battery is crap.I bought the cheapest I could get my hands on.just to make sure everything ran. I will be getting a 3s lipo very soon. I would have one already but I didnt want to buy one yet with my current issue unresolved.so, it could be the battery that is causing loss of control? If so, I will order a battery and charger today
The problem is the throttle.
-program the Radio and ESC together(follow the Radio and ESC instructions)
-then; (it could be) the Throttle Sub-Trim has to be set
When it happens, after you retrieve it, if you pick it up and power cycle the system, does it act normal again, but runs away when you put it on the ground and give it throttle? Then for sure your losing signal. Do you recharge the battery to full capacity? You have a pretty low turn motor and a pretty small battery.
I'd try to borrow a larger battery (more than 1800mah) to check it out first, but this sounds like the system is browning out and the speed control locks on the last signal it received.
When I pick it up it just keeps running full throttle.nothing changes until I turn off the esc.then when I turn it on again everything seems normal.
It sounds like the Speedo is not bound to the Radio.
I have the Tower Hobbies 224 system. How (if possible) can I set the sub trim? There is only one know for throttle trim but I do not see sub trim.
Then for sure your hitting the low voltage. You can recalibrate it till the cows come home and this won't fix the problem, your just plain and simple running out of battery.
Thanks for the help
Some radios have a fail safe option, thats something you'll have to check into with your transmitter information. Ultimately though its your battery thats down to a lower voltage that will not sustain radio signal.
My touring car was doing this when I first got it going. It turns out I did not calibrate the esc properly. Once calibrated, I have had no issues since.
You could try a surge cap that plugs into the receiver, but that usually just helps when you punch the throttle, it keeps voltage up for a milliseconds so the radio signal doesn't drop.
