Improving transmitter flow
Are there any tips or tricks how to make steering and throttle usage more flowing? One of the fastest racers said that I lose quite a lot of valuable time in the corners because my finger movement in too aggressive. We did try to soften the steering by gluing foam to steering wheel endpoints, which improved my best time about 0.2 seconds. I am racing 17.5 Blinky with a Sanwa MT-4S.
lower the "Dual Rate" setting until the car will not make the tightest turn and then go back up a little at a time until it makes all turns but feels smooth.
If you have a super fast servo like .07 seconds, use the servo speed setting and set it for -9 out and -3 return
+1, I would use exponential too.
Thank you for your answers, I will try them next time I go practice. About throttle usage, is it faster to a) brake hard before a corner, hold half throttle in corner and then accelerate or b) to slow down before a corner, hold neutral or slight throttle in corner and then accelerate?
I have the Sanwa MT-4S (40th anniversary), wheel shimed 1mm to remove rubbing, springs as loose as can be, slop removed with VR adjust, JC wheelfoam and pieces of foam glued to wheel endpoints and throttle lever.
radio
My driving was improved by stiffing the wheel spring,helped to calm my car around center more along with radio settings with the expo
I previously had the steering in the mid-range stiffness, but the same guy, the fastest guy in our country and his father, told that a looser setting results a more precise driving.
I feel that Expo is a lazy excuse for poor driving habits. I know a lot of people love expo, but I dont think it should be used as a crutch in the beginning. If you need to dial out steering in the beginning of the throw and then make up for it later you are doing something wrong at the radio.
