4WD - Do you allways run matching tires front and and rear?
Do you ever run say the softest at the rear and only chance the front tires when you get traction roll?
Short answer, same tyre all round.
Longer answer, most races these days have a control tyre in a single compound, so you have no choice.
Years ago, before tyres got so controlled, some people used to use a harder compound on the front if the car had too much oversteer. It's an easy fix, but usually you'll go faster with the softer tyre front and rear.
I have run harder compound tires on the front when running outdoor on asphalt. The idea was to have the tire's grip "go off" at the same rate, eliminating the need to rotate tires (since I run so many classes I didn't really have the time). It works okay, but takes some experimentation to find which compounds and matching setup keeps the car's handling balance optimum for the longest time.
The answers have already given you some hints of what to consider.
Even if you run the same tyre, it will be necessary to rotate them, because the wear rate is not the same and you will end up with "different' tyres front-to-rear anyway if you don't rotate.
I am a cheapskate and keep al old tyres until they disintegrate. This means that some times I run different tyres, which creates problems. A quick run before the race tells me if I am set to go or not. Sometimes.
Rotating front to back is never a good idea though.
Left to right if the track you are at has uneven wear can help longevity.
Super Moderator
