What adjustments do change first!
#32
Today I raised my rear inner link height by 2mm. It makes the rear end very loose, fish tails and oversteer.
I didn't like that so I put it back to stock. From I have read, this adjustment lowers roll center. Is that correct?
#33
2mm is a huge change. I do 0.5mm at a time
#34
To free up the rear of my car I sometimes add another 1mm. But I think the biggest difference I've ever had front/rear is 1mm
#35
The original height is 0mm, stock.
I will say for the record I am running a front mount motor so any changes in the rear end are probably amplified compared to those in a mid motor mount car.
Yes I understand that 2mm is a huge change. I wanted the change to be glaringly obvious, since I am learning. By my observations it loosens the rear end when exiting the corner.
To be clear, I changed the camber link height, not the arm link height.
I think if I had raised the arm-link height it would have resulted in better on-power traction out of the turns.
#36
How did you manage that, anyway? Arms should be parallel in kit setups.
