Help with AE part no's
Can anyonewho runs a TC4 kindly supply me with some part numbers, i've searched and can't seem to be able to find them.
I need the part no's for the complete driveshaft assembly and the outdrives for the heavy duty one way.
Many thanks
Many thanks
Many thanks
Many thanks
3979 TC3/4 Oneway outdrives
3903 Drive pinions "Need 2 of these"
3911 TC Transmission Shim set
3915 TC3/4 Input shafts...front and rear
3919 Input shaft hardware set
3977 Bearing 3/16 x 3/8 rubber sealed "Need 4 of these"
31019 TC4 Driveshaft accessories Spur gear hub, drive cups, bulkhead
31021 TC4 Main Driveshaft
http://www.teamassociated.com/misc/d.../db_kittc4.htm
There you go. Merry Christmas!
Originally Posted by Rick Worth
Did you try here: http://www.teamassociated.com/shusti...hub_onroad.htm
31034 dogbones
3886 axle
7381 accessories
Many thanks
Originally Posted by Soviet
Soviet to the rescue!!!
I knew someone would say that , I actually meant the part no's for the driveshafts, don't worry got them now. Is that the part no for the heavy duty one way outdrives, as they are quite a bit different that the std ones?
Had a look on stormer hobbies website and they don't list the part no you've given me anymore.
