Platinum Lipo
#406
Originally Posted by rcdougie
Anyone fit a Lipo pack in a RDX yet??
#407
Originally Posted by lookinco
Will there be any problems to the brushed motor if it is being run at a racing pace for 15minutes continuously? For example, would there be problem of over heating, burning up the brush, etc etc?
#408
With a V2 you will have no problem running 15-20 minutes !
#409
I ordered two Lipos so I hope they are good. Question...
I want to get the most out of them, how do you balance the cells? Do I need a charger that will balance them? If so, highend charger do you recommend?
#411
From what I understood you can use any charger charging one cell and charge first cell one using the positive wire of your charger and plug the negative in the 2mm tube on the back and then you charge the second cell by pluging the negative wire of the charger to the negative pole of the battery and the positive on the little 2mm tube on the back.
It will fully charge individually both cells and re-balance them.
#412
That would be very simple, and possible, that would mean that de small hole on the rear just connects to the 'bar' that connects + from one to - from the other cell...
I'm wondering why doesn't orion mention this feature??
#413
Who has tried to balance it ?
#414
Anyone that's wondering the Orion Lipo will not fit in a Xray T2.
That sucks, since I just bought two of them. I hope Xray and other companies will start making a chassis that will work with them. I had to mod my XXX-S so I guess I can use them for street bashing.
#415
#416
Hello Adrian, have you tested your Platinum packs ? If I remember well you where waiting for your Advantage Carbon charger ?
#418
Regional Moderator
Originally Posted by AdrianM
In case you are curions this IS the process for balancing LiPo. You fully charge each cell individually...this balances the pack.
Seems like a really simple process.
Any idea as to how often this would be neccesary. I know that Orion doesn't feel its all that neccesary.
#419
Originally Posted by Darkseid
Interesting...
#420
Adrian, since I hear you are the EXPERT when can we have your feed back on the Platinum and the Advantage Carbon ? Thanks
