MBX5
#1366
Originally Posted by Jon Kerr
Keep a full set of arms (front upper and lower and rear) set of pillow balls, clutch parts, clutch bearings (stock up on these. I'm changing them every race day to be safe.) hinge pins. Pretty much spare parts you'd stock for any other car. I broke my car for the first time this last weekend. Has anyone ever had the lower pillow ball pull out of the suspension arm? I had it happen twice. Once on each side on the same day. Cost me a fast qualifier and a second bump up into the A at the Saturday series.
#1367
Originally Posted by quietstorm76
Hello, I just ran my MBX5 on the track for the first time and I it handled pretty good but I couldn't turn tight at all. Every corner was wide. It seems that there isn't enough steering throw left and right. I've heard people say that the standard X-5 doesn't have a lot of steering. Are there any mods I can do to the steering?
#1369
Here are a few reference pics....
#1370
Theoretically, the 48t gear shouldn't give a different actual ratio than the 46t. A true gear ratio is the ratio between circumference of two circles. If these two circles are the same diameter they should produce the same ratio, regardless of tooth count. I am told the differece is noticable so what do I know...
#1373
The gears are the same size so that it does not cause mesh problems. It's the same way with on-road cars. We can change gears without touching the gear mesh. So on the off-road you can do the same thing.
#1374
Originally Posted by mugenlife
you can do the R front arms and up rights, but to be honest sounds like you dont have your brakes set up right for how you drive. i tap my brakes when i turn the whole car rotates very easy.
#1375
Actually the motor (clutch bell) needs to turn 3.69 times with the 48T spur opposed to 3.54 times with the 46T spur gear (13T clutch bell). So the diameter has nothing to do with the ratios. With a belt on a pulley, then it would make sense
Best regards,
#1376
I posted this on the S-grid a few weeks ago ....
Stock Losi 8ight buggy: 43/13 Ring & Pinion, 48/13 Spur & CB = 12.21:1
Stock Mugen buggy: 40/12 Ring & Pinion, 46/13 Spur & CB = 11.79:1
Mugen with 48T Spur Gear = 12.31:1
...and people wonder why the Losi accelerates so hard.....LOL
Sure the Losi 8ight is lighter (mostly saved weight in the drive train too), but it is geared much lower as well. The 48T spur gear on the Mugen makes them much closer.
#1377
Originally Posted by REVOS5
Hello RCTECH
I am in the market for an MBX-5R. I used to drive an XB8, but couldn't get the rear end to calm down at all.
Few questions. Which tires/wheels work best with this buggy. I read about the diff o-ring/gasket problem. What's that about? How does it compare to the 8ight?
Thanks in advance.
Thanks in advance.
Best regards,
#1378
I think that is a good point about the size and not the teeth. If the tooth count actually mattered the 415 would be way off since it only has half the teeth on the pulleys. Also if you had enough force to hold them together you would not even need teeth, friction would drive them. Bigger tires go faster than smaller ones right. By the way i am saying i am an expert, just pointing out what makes sense to me.
#1379
[/QUOTE]
THE MUGEN IS the best buggy i ever had!!!!!!!!!!!!!!!!!! and i've had plenty....
[/QUOTE]
#1380
The outer diameter of the gears are the similar in size to accommodate the chassis but it is the tooth count and gear pitch that determines it's final ratio. If it was a friction drive than the diameter of the gears would determine the ratio. Actually a smaller tire turns faster than a larger one. I also don't claim to be an expert just speaking from experience.
