MBX5
#1276
what i did on mine was after i put them together i set them up overnight (screw side up) then retightened them. so far after a gallon so far so good no leaks.
#1277
Like many many people have said. The trick to diffs is grease. Use a waterproof marine grease or like some people have started using is mobile one synthetic grease. Grease the o-rings, conical gear shims, out drive shafts, and gaskets liberally with grease. Grease grease grease.... Don't wipe if off either... it makes a mechanical seal. No need for after market o-rings.
#1278
AE Green Slime is also great for diffs!!!!!
#1279
The only thing I could never get to stop leaking by using grease was Losi shocks. I did all sorts of things. New seals, different material seals, different grease, more grease, less grease, no grease, .. I just think Losi is cursed for leaky shocks. They look great too! I don't understand why I couldn't get them to stop. I even used the v-style o-rings with double contacts. Still leaked...
#1280
When I ran my Jammin FTE I used Kyosho diff gears only!
Jammin gears arent reliable..
Just traded a Losi 8 for the 5R... I am stoked..
I sold my 5T with less then a gallon on it and am kicking myself..
I have read all the good info in this thread and hope I can contribute
as I get some time with the car..
#1281
Did you guys see this on Neo Buggy?
#1282
http://www.the-border.com/search.php?mode=search&page=1
#1285
Originally Posted by TonysScrews
No reliability issues at all. I know guys that have ran two gaskets for over 10 gallons and the diffs are fine. Didn't have to go up in oil weight either.
I will be leaving them stock for the moment .
cheers from Downunder
#1286
I want to know why we dont have the new RMV progressive spring for the mbx5r with the long shocks. I know the mbx5t's are the same but you only get 4 rear springs..... I want some for the mbx5r front shocks???
#1287
Originally Posted by ira
Mugen/Ninja DOMINATE Again
Corey with the MBX5R dominate the big money race at Leisure hours hobbies, turning the fastest lap time.
#1288
Originally Posted by mugenlife
sweet any place that has the results?
click on leisurehours raceway
#1289
do they run alot of the R's there?
