TT-01 Forum
#1276
Im drifting with a vortex 7.5, 67/21 gearing, i think its around a low 8ish FDR, its got plenty of torque, but im looking for a little more power now. i dont want to gear any lower because the motor gets hot enough as it is. i want to keep the same FDR, but get either a higher kv 7.5, or a 6.5...
#1277
Ok so im racing my TT01 in a spec class, but am running it at another track this weekend and they dont have spec, so im running stock. With a 17.5bl and 23/58 gearing, do you think i will be able to keep up very well or do i need a larger pinion?
#1279
#1280
hey guys i just got a 5.5t brushless for my tt01 but im having trouble at high speeds theres just so much steering wobble and i often loose the rear end . any suggestions on how i could tackle this? upper frame? sway bars? oh and should i run softer springs in the back to give me better handling?
#1281
#1282
I may be able to offer suggestions, if you provide more details on your car.
What options and upgrades do you have. Particularly. What upper and lower arms do you have? Is the car stock, or a -D, -R, or an -E?
Kevin
#1283
hey kevin thanks for trying to help
ive got a normal tt01 kit but its got quite a few upgrades
alumin shaft , ball bearings , oil shocks, pretty sticky foam tires because i drive on the road mostly.
5.5t + 60 a brushless ezrun combo . ive got the yeah racing upper arms for the front but all the other arms are just normal . i have gears if i want to change the gearing or sumfin . i also have tierods on front steering but atm they are set to 0
#1286
#1288
I have just got the ball diff set for my TT01, planning to use it for drift but unsure how to adjust it... How many turns should I adjust back from the fully tightened position for the front and rear? My current setting of 1 turn on both front and rear makes the car push Oh..please advise...
#1289
for my TT01 drifter, a while ago i was using a diff locker in the rear, & a semi tight ball diff in the front. for the front, adjust the diff so it acts similar to an lsd, so you have the traction from both front wheels when needed! Im now rocking both fully locked diffs, my ball diffs teeth stripped, not the plastic part!
