TT-01 Forum
#481
lights? TLU-01 LEDs
What are those lights? any ideas on how many volts for additional LEDs for the TLU-01 light kits?
#482
HELP Tamiya Shop in Manhattan - New York
hello everybody!
I'm an Italian Pilot of TT01.
In September this year I'm going to NY (Manhattan).
Sorry, I need your help because I will stay there just 10 days , I would like to ask you if you know any delear Tamiya shop (name and address) where I can buy Tools & Accessories.
Thanks a lot for your reply
Kind Regards Maxtamiya
#483
better if you use car light bulbs they last a lot longer,,, they are usually rated at 12 volts they draw 2amps per bulb,, so if you want a 20 amp discharger create a discharger with 10bulbs 30 amps then 15 bulbs,,, a 20 amp discharger is an all rounder,,, you can use it on stick packs with low capacity cells or side by side configuration batts with high capacity cells,,,
is it the one use for tamiya car "led light for drifting"?
so sorry so stupid about electronics and cars
if i go to hardware or electronic shop can i simply say "im ordering car light bulb"
anyway to make a bulb discharger simply wire all the bulbs in parallel ( i used galvanized wire on mine i can shape it the way that i want and it's really easy to work on ) with the ";butts" of the bulbs representing positive and the side of the bulbs representing negative. ..
again so sorry sigh! this one confused me,
can you show me a pic of finish product so i can get a better idea
thanks for you help
i will wait for the images
#484
10 bulbs is considered "standard"
Yes "12 gauge" is the thickness of the conductor in the wire.
#485
Front Spool for TT-01?
Guys,
Had anyone tried running a TT-01 with a front spool from locked ball or gear diff?
Can share with us about its performance at corners using TC tires only?
Appreciated. Thanks!
#486
i tried running a spool upfront, all i did was place hot glue on my center diff and viola i got myself a spool. anyway it really performs great on corners as compared to the stock differential,,, only problem though was with stock steering assembly its kind of hard to get a straight line out of the kit,,, overall it gave me better runtimes,,, try it yourself if it doesnt fit your driving style,,, you can always use the spool on your rear for drift setups. cheers!!!
#487
Thanks!
#488
is there a way besides getting the new lower A arms (which i plan on getting) to be able to set your shocks in different shock tower holes positions.I have read this whole forum and i could not find any thing. this might help others to. thanks
jake
jake
#489
speaking of arms, does anybody know how to get rid of there slop/play??
#493
The TT01D arms have 2 mounting holes for the suspension.
I was thinking with the slop in the arms caused by the arm holder holes being to big, fitting heat shrink around the arm where they mount into, but the heat shrink was just a little thick. Does anybody else have any other suggestions??
#494
weak parts
what are the TT-01 weak parts. which parts you break replace the most.
i just need to stock up on parts as ordering online is soo expensive and i have to wait for quite some time. thanks.
#495
get yourself a hold of the tt-01 A parts, it's about $11.59 at towerhobbies.com,,, i've had my tt-01 for 2 years now and every part that i broke was in this bag.
