TT-01 Forum
#1546
hey slim, where did you get the red battery brace?
#1547
Question regarding gearing
I finally got the tt01 running strong everything was great but im having some problems with the gearing end.
I ran 19/61 car was fast but got WAY to hot, basically to the point where i couldnt even hold the motor, so i turned it off let it cool and started looking at other pinions.
Im come to try 25/61 but i cant get any mesh to work the gears are just to big it seems to fit inside the case.
Is anyone running 25/61 or something similiar..
im running a 17t brushed atm
#1548
i was running 25/55 but now im running 28/55 with a 21t motor and it runs cool, i don't think a 25/61 will work
#1551
Suspended
max voltage
good day gents
what's the maximum voltage a TEU-101BK can handle
I saw a 7.4volt battery pack, and just want to asked first
before I purchase the pack
#1553
Suspended
BTW, its 4 pieces li-fe battery pack 7.4v
but the store said its configured as 2 cells
so i need to set it to 2 cell on my muchmore
anyway, you said something about a 3 cell liPo
will a 2 cell li-fe pack work-out w/ my TEU-101BK?
#1554
Argh i need traction with my tt-01 if i put the power on it spins up don't get me wrong it is fun but when coming out of a turn just about to go straight full power to get away from the field and the car spins started to do my head in. is it the tyres or the setup up im runnning.
im using a 21t motor 28/55 gears, tamiya slick tyres (so far reallly not impressed with them)
#1555
Suspended
FWD
hey guys have you tried, removing the 2 rear dogbones
off the TT-01, just to make it a FWD car?
just curious, I mean, better to ask first, rather than regret the outcome.
#1556
The Tamiya 26mm tires are not as good as some others out there. For general running around on unprepared surfaces, I like the HPI Pro Compound Belted X-Patterns. About $30 for a set including wheels, they last pretty much forever, there are like a zillion HPI wheel patterns in various offsets (try the 3mm offsets for your TT01), and they have very consistent traction. We used them for our spec tire in Senior Spec last year and everyone liked 'em.
#1557
Suspended
thanks RaceBucks, BTW can I print your chart?
then stick it on my tool box, for future reference?
#1559
Suspended
#1560
If you go to Tower Hobbies' web site and checkout the HPI tires, you can see them and the choices. You get the stock numbers and your local shop can order them from you. When you get the stock numbers make sure you get the manufacturer's stock number, not Tower's. You can also Google the stock number and find cheaper online prices.
