TT-01 Forum
#137
I thought that the F201 52t shaft hole was to big to fit in the TT-01. Any insight?
#138
Gearing
Hi, i am planning to drop in a 19T motor for my TT01, How many "T"s gears set do you all recommend?
#139
Has anyone race TT01 on the carpet? can share the setup to me? Iam running sport tune motor, with trf short shock absorber, centre aluminium shaft, full ball bearing, adjustable turnbuckle. and the rule mentioned that we cant use other brands for option part. (Tamiya Parts only)
Many Thanks
Many Thanks
#140
Any one know the part number for the 52T spur and where to buy in AU. Thanks
Taffyjnr5
Taffyjnr5
#141
Does anyone use their tt-01 for rallying? Does anyone have tips for it?
#142
I am putting my tt01 up for sale, never run my son got a TAo5 it will include the Novak 4300 Brushless motor and esc. This car is loaded with hopups the only thing it needs is the Fr one-way. if interested e-mail me a [email protected].
#143
Originally Posted by gijoe64
Here are pics of my sons TT-01, I would like to get TRF shocks, front one-way and the alum shaft out-drives. It is pretty loaded!
Nice car u have... have your son ever race it? how thick is the carbon upperdeck?
#144
put thick oil into the front and rear gear diff.. use 58T spur combine with 22T pinion or 23T pinion. If possible use trf shock absorber. fill it with 40 front and rear. about the tyre.. it depends on what kind of surface that you will run.. how rough the surface, and how sticky it is?
#145
Thanks for the help man.
#146
Guest
Originally Posted by nino_pohan
Where can i get pinion gear 26T and 27T, have tamiya made that pinion?
#148
We will be running the car this weekend. The top deck I think is 2.5mm. I really worked on the drive train and suspention
#150
TT-01
I am running a 17t LRP GT3 motor on my TT01D, i ran it on a 58 T spur with a 19 T pinion and it tends to heat up my esc n motor, other than these, what other gear set ups do you recommend?...thanks.
