Checkpoint 19turn spec mod
#331
Anyone know the difference between the MF-Mab and MF-MAK (Type 1 vs Type 2) endbell fan posts?
#333
#335
Thanks for the help Nexus!!!
What springs and brushes do you guys run in races vs what you run in practice? I am running 4wd touring car outdoors on prepped asphalt. Looking into what I should run for practice, and what I should run in the race.
#336
Registered User
Originally Posted by AdrianM
The bursh you run depends on how much work you want to to. Atlas brushes with standard springs (med) are really good on 4 cells. If you want go really fast this is good for 3 runs...the 2nd seems best. Then you need to cut and rebrush. Infinity brushes are just a tiny bit slower on 4 cells but last FOREVER. You still need to cut the comm every 3 runs but you just leave the brushes in there.
#337
Originally Posted by Dasupacat1
I've run the Atlas brush for about 10 runs. Cut it after 5th run. It's still fast as hell. I run touring rubber/carpet on a tight track with an 80' straight. Last week I pulled a car so hard on the straight. He had about 2-3 car lengths. and had more than a few people in aww at how fast it was. The car I pulled was not dumping and was at full throttle cuz' the driver came up to me and was like what kind of motor you got? Showed him my Brood tuned money w/Atlas brushes, silver+/gold- springs. He ran a Trinity KD I believe. I don't see the Atlas brush as being throw outs after a few runs.
#338
In FL we have to run the Infinity brush due to heat in the summer time (100* air, up to 155* track). With that brush and the stiff springs you can run a monster gear ratio in a sedan (5.2FDR) and the car is ballistic.
I have heard some guys are running the Orion MR V2 spring in the Check Point 19T and Mod and you get even more power and brush life.
With the CP stiff spring the 19T is fast for ~2 runs on a hot day before you need to cut the com. The Infinity brushes are good for 15-25 runs.
#340
checkpoint 19t so where do i get one from?
#341
I can understand how the outside temps can make brushes go quick. I run indoors. We'll see during this summers off road program.
Money 19T's last forever in offroad so you can run Atlas brushes and run an entire day without working on your motor.
#343
Has anyone had glitching problems with their money motor? I am running one and have always had some glitching issues at the end of a long straight. Has anyone had to add additional capacitors on the motor?
#344
your not over reving it and getting brush bounce are you? how hot is it comming off the track?
#345
Since it is just practice, the motor is about 150-170 max the past few days. The motor was just cut and rebuilt 1 week ago.
