Team Magic G4
Lars:
understand this could be an issue, however wouldnt standard position under fuel tank be an issue as well?
What car are you running now? Still the Shimo?
Andrew
The 09 may not work.. but the Mongoose will fit an RS08 ED transmission upgrade which includes pulley upgrades and vented disk brake. 2nd gear spur changed diameter and you can still use mongoose first gear, also pinions are smaller.
Add a clutch upgrade and you might be better off buying a second hand G4RS08
Hi
Sorry if spelling or grammar errors I am typing this on phone.
I tried to run my girl friends G4JR today, and on the starter box I noticed the steering servo was twitching. On the track it pulled to the right into the wall under acceleration. When I got home I tried another receiver pack battery and it did the same thing and then the throttle servo twitched as well. Anyone got any suggestions?
Thanks in advance
Andrew
Thanks in advance
Andrew
Hi
I tried to run my girl friends G4JR today, and one the starter box I noticed the steering servo was twitching. On the track it pulled to the right into the wall under acceleration. When I got home I tried another receiver pack and it did the same thing. Anyone got any suggestions?
Thanks in advance
Andrew
Thanks in advance
Andrew
bummer
Hi
Thanks in advance
Andrew
Thanks in advance
Andrew
I'd suggest trying a different receiver as the Capacitors may be insufficient or dead and bleeding. If you look in your receiver and teh Capacitor head has expanded or popped, could be where the problem lies.
You can also get caps that plug into the receiver buss aux port.
OR...
a bad connector.
Trader Rating: 13 (100%+)
Hi
Thanks in advance
Andrew
Thanks in advance
Andrew
Kindest regards,
Lars.
It might be your throttle servo is drawing all the load. This happened to Luke's EP car and a stock standard Futaba AM receiver.
OR...
a bad connector.
OR...
a bad connector.
Thanks for the suggestions... I know all about bad capacitors as i work at a leading computer store
I have now tried different servos and it appears to be just the steering channel.
Chickentrader:
You could be on to something, when i took the PCB out of the receiver case, one of the steering servo pins was bent.
And using my Spektrum DX3R in the car using the same servos and battery everything works fine!
Guys, I had a similar issue with a JR FM Syn Radio.... after trying multiple servos, receivers, batteries and Transmitters I changed over to a Sanwa 2.4 FHSS system and never had the problem again.
Does the problem occur when you are not running the motor?
Blis:
Chickentrader:
Chickentrader:
G4+EVO
Does anyone own G4+WC/EVO ?
Asoff as it even seems to me, it took a lot of deliberation when the parts list for running the champs came to 1/2 that of the car, so wildly I chose to buy a whole car rather than the usual consumables, would like to know what ppl rate the G4+EVO versus the G4+ LE 07 version.. pro's or cons.. should I run the G4+LE or the WCEVO.
Our G4+LE is a preserved RACE car with barely 1 hour track time.
Are shocks better? Should I swap over to newer chassis plate or stay with 4mm?
Should I build a hybrid?
h
h
Hybrid
h
h
h
h
Re: g4 wc upgrade
From: Team Magic Service <[email protected]>View Contact
To: Rezuan Rusli <[email protected]>
Hi Rezuan,
Thanks for the mail .
You could use K14145 kit for upgrade to WC. And we suggest you could buy the kit from RC Shopping directly and pay via Paypal.
http://www.rcshopping.com/profra.jsp...4145&proclass=
ITEM NO. DESCRIPTION PRICE
K14145 G4 WC Upgrade Kit 201.20
K14145-1 G4 WC Upgrade Kit (Front) 49.80
K14145-10 G4 WC Alum. Rear Left Bulkhead 27.10
K14145-11 G4 WC Chassis 74.70
K14145-12 G4 WC Rear Front Hinge Pin Mount 14.60
K14145-13 G4 WC Rear Rear Hinge Pin Mount 14.60
K14145-14 G4 WC Rear Plate 3.60
K14145-15 G4 WC Rear Adjustable Anti-Roll Bar Pin 2.5x48.5 mm 4.05
K14145-16 G4 WC Rear Hinge Pin Mount (plastic parts)(4) 2.70
K14145-17 G4 WC Front Upper Arm Mounts (plastic parts)(4) 2.70
K14145-2 G4 WC Upgrade Kit (Rear) 162.00
K14145-3 G4WC Bumper Foam Post Set (2) 3.60
K14145-4 G4WC Front Bumper Upper Plate Carbon 18.90
K14145-5 G4WC Front Bumper Cap 5.85
K14145-6 G4WC Front Upper Arm Mounts (2) 33.20
K14145-7 G4 WC Alum. Rear Right Bulkhead 27.10
K14145-8 G4 WC Alum. Brake Lever Set (w/steel piston) 4.27
K14145-9 G4 WC Rear Bulkhead Plastic Support 2.70
BR,
Team Magic Model Service
+1 on the hybrid idea. I used the WC upgrade kit with my RS08, cost $160 because Wolf happened to be running a sale at the time. I decided not to go totally new with an RS09 because of too much spare parts incompatibility. The WC upgrade was definitely an improvement for the RS08. So at the end of the day, I got a much improved car (same or better than RS09, plenty to debate there ????) and still got to make use of my spare parts inventory.
tks
Feedback much appreciated
h
