Team Magic G4
#6331
No nead to appologise my friend...............I'm a very light hearted person and very hard to offend as some of my competitors on the track can vouch. I don't get mad very easily..
You stay in your witty mood my friend.
Hey.......if you get your eyes tested, will that mean you'll become an even better driver Patto...........? Look out everyone down under
Hey, I have to go. Good talking to you my friend.
Regards,
Menace
Regards,
Menace
#6332
Originally Posted by British Menace
Well it has been a while since pottery and camera class at school...........lol
I have to go and build a trampoline for the youngster now.......
One of the jobs I have to do before I go away this weekend for the Big race in Cincinatti.
Rather work on the car as it's in a million pieces at the moment
Still, family does have to come first.................only by a neck, but still first.
Menace
Menace
can always invite the kids next door to do the initial bounce test
saves you a trip to the hospital.
#6333
Car question?
After watching a RC Pro Series race this weekend, I have decided to purchase a 1/10 scale car. Since I am also in the process of shopping for a home, the car is going to be something economical but still competitive on a sportsman level.
I was considering a RDLogics Mongoose with a JL Red Dot .12. The track I would be running on is large (301 Raceway in Maryland) and pretty flowing. Good choice? I am open to all suggestions. Thanks in advance.
#6334
Another....
The two speed housing I felt could be improved. As you can see in this photo, some extra material has been milled out and one large bearing instead of the two was also fitted.
This new bearing is 5mm wide so there neads to be a shim between the bearing and the drive pin that locates into the two speed cam. I felt the speed the two speed shaft runs at, (17,000 rpm with stock gearing, 13,000rpm with ED) it's very hard on those small bearings.
Menace
Menace
#6335
Another....
Menace
Menace
#6336
ED vs Standard Gearing
has anybody tried to run and Ed transmission with standard kit pinions? If so what was the result?
#6337
#6339
Originally Posted by razzor
BM i take it teh housing is milled straight through and that the bearing should sit flush to rear of housing ???
Although I did leave a very small lip on the front of the housing just for the bearing to seat on.
The bigger bearing does handle the speeds and the forces involved well although a ceramic would be even more so
Menace
#6340
Well, just thought.
It's almost flush1
Just leave a little protrusion at the back.
Only small. I left the bearing protruding out of the housing at the rear about 0.010"
To run on the baulkhead bearing.
Menace
It's almost flush1
Menace
#6341
Originally Posted by Pattojnr
Dan, last round i ran 3mm shorter rear wheelbase. the car came alive in the steering department for sure, but i didnt really notice any stright line stability problems at all. i have found that doing this mod has helped the steering so much, i can now run harder front tires and springs, which has to help in the long run
Thanks Patto,
I was struggling for turn in up at Bunbury so am hoping this mod will assist. Have also made some changes to the rear so hopefully it sticks nice. See you Sunday.
#6342
diff
Hi when you are using a spool diff infront what diff oil I can use in the rear?
Joe
Joe
#6343
Please help
Hi there
Can anyone please help me. I have started to hop up my g4 and purchased the k factory chassis with carbon stiffners and the 3 racing carbon side stiffners and alloy radio plate supports. but as i've fitted them all i carn't see how the throttle/brake servo fits in as the side stiffner on the clutch side is longer towards the front fo the car. Can anyone help
Regards Rodney
Regards Rodney
#6344
Originally Posted by Rodney
Hi there
Regards Rodney
Regards Rodney
#6345
guys, I've installed K-factory fuel tank and so pleased with it since I was able to adjust pressure nipple side according to high speed turns on track. One thing is I suspect if it's leaking at the rear of cap. If I remember correct it was written here about it but can not find it.
Do you remember about it?
Asil
Asil
